- mariusl
12 years 7 months ago - 12 years 7 months ago #44453
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Norbert
I did the hard reset already and compiled as per usual. I then copied the sim directory of gmoccapy to a config directory. I then removed all sim related stuff and I get this when I load. I takes a looong time to load and then the buttons dont work.
Regards
Marius
www.bluearccnc.com
Last edit: 12 years 7 months ago by mariusl.
- verser
- Thank you received: 69
12 years 7 months ago - 12 years 7 months ago #44455
by verser
Replied by verser on topic Gmoccapy - A new screen for linuxcnc
Norbert, there is a huge request,
to complete the work on the compensation Z (and more) requires space to insert it.
It is possible to add a hide blank panels in gmoccapy.glade here
and in gmoccapy.py here
insert code
insert code
if "box_custom" in self.get_ini_info.get_embedded_tabs()[1]:
widgetlist = ["box_custom_widget1","box_custom_widget2","box_custom_widget3"]
for widget in widgetlist:
self.widgets[widget].hide()
self.widgets.btn_tool.set_sensitive(False)
self.widgets.tbtn_user_tabs.set_sensitive(False)
Last edit: 12 years 7 months ago by verser. Reason: edit
- newbynobi
- Thank you received: 394
12 years 7 months ago #44456
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo Marius,
does gmoccapy start in normal sim mode?
The error is shown in your log file as HAL: ERROR: duplicate component name 'inihal'
I do not know what USERMOT does exactly.
Please post you hal and ini files.
Norbert
Norbert
- newbynobi
12 years 7 months ago #44457
by newbynobi
@verser,
I am not able to follow you.
In the image showing the themes problem you panel did fit, so why introduce new panels and hide them if custom:box is in embedded tab?
Could you explain more in detail?
Norbert
Norbert
- mariusl
12 years 7 months ago #44458
by mariusl
Regards
Marius
www.bluearccnc.com
Norbert
The sim loaded ok.
The sim loaded ok.
Regards
Marius
www.bluearccnc.com
- newbynobi
12 years 7 months ago #44459
by newbynobi
Hallo Marius,
You commented all Hal files out!
I am pretty sure, that that is not allowed, as you do not load a thread or any other stuff.
Where is your config from your machine?
Norbert
# Hardware Abstraction Layer section
[HAL]
#HALFILE = core_sim4.hal
#HALFILE = spindle_sim.hal
#HALFILE = simulated_home.hal
# Single file that is executed after the GUI has started.
POSTGUI_HALFILE = gmoccapy_postgui.hal
HALUI = halui
Norbert
Moderators: newbynobi, HansU
Time to create page: 4.114 seconds
