12 years 7 months ago #44640 by jbunch
Replied by jbunch on topic Gmoccapy - A new screen for linuxcnc
I did a git pull today.
I receive the error unable to find program gmoccapy on startup.
When I look in the linuxcnc-dev/share/gmoccapy structiure all I see is images.
no skins or tcl directory as the other interfaces have. What am I missing.
Jim
12 years 7 months ago - 12 years 7 months ago #44654 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Did you do:
cd linuxcnc-dev
cd src
make clean
./autogen.sh
./configure
make
sudo make setuid
Norbert
P.S. there should be a file gmoccapy in the bin dir and the glade file is in the share/gmoccapy folder, all other files are in the lib/python/gmoccapy folder
Last edit: 12 years 7 months ago by newbynobi.
12 years 7 months ago - 12 years 7 months ago #44668 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
No bugs this time, just a question please. I am using the buttons on the left panel for my mill to send the spindle to a tool change position or a park position and also to probe the material offset. I attached the sub that I am calling from the button. My question is, will this sub work with the Auto-tool-probe of Gmoccapy? I usually run this before I run the gcode program.
EDIT: I use a touch-off plate of 1.6mm for this, not the switch
File Name: probe_material.ngc
File Size:0 KB
Regards
Marius
www.bluearccnc.com
Last edit: 12 years 7 months ago by mariusl.
12 years 7 months ago #44675 by newbynobi
Halo Marius,
not out of the box.
Forget about the probeheight button and just edit the change.ngc according to your needs.
Find the file at:
configs/sim/gmoccapy/macros/change.ngc
you will have to copy the file to the place your subroutines path is.
Norbert
12 years 7 months ago #44677 by jbunch
Norbert,
Yes I did a clean build.
There is no gmoccapy file in :~/linuxcnc-dev/bin$
:~/linuxcnc-dev/bin$ ls
5axisgui hal_input io milltask shuttlexpress
axis hal_manualtoolchange iov2 ngcgui stepconf
axis-remote halmeter keystick pci_read teach-in
classicladder halrmt lintini pci_write test_rtapi_vsnprintf
comp halsampler linuxcnclcd pncconf tooledit
debuglevel halscope linuxcnc_module_helper profile_axis touchy
genserkins halshow linuxcncrsh puma560gui tracking-test
gladevcp halstreamer linuxcncsvr pumagui vfdb_vfd
gremlin halui linuxcnctop pyngcgui vfs11_vfd
gremlin_view hbmgui maho600gui pyvcp xlinuxcnc
gs2_vfd hexagui max5gui rs274 yapps
gscreen image-to-gcode mb2hal scaragui
halcmd inivar mdi schedrmt
there is no directory gmoccapy in :~/linuxcnc-dev/lib/python$
:~/linuxcnc-dev/lib/python$ ls
bitfile.py gremlin.pyc hershey.py popupkeyboard.pyc _togl.so
bwidget.py gremlin_view.py hershey.pyc propertywindow.py touchy
bwidget.pyc gremlin_view.pyc linuxcnc.so propertywindow.pyc vcpparse.py
gcode.so gscreen linux_event.py pyngcgui.py vcpparse.pyc
gladevcp hal_glib.py minigl.so pyngcgui.pyc vismach.py
gladevcp_makepins.py hal_glib.pyc nf.py pyvcp_widgets.py yapps
glnav.py hal.py nf.pyc pyvcp_widgets.pyc
glnav.pyc hal.pyc nf.py.in rs274
gremlin.py _hal.so popupkeyboard.py stepconf
:~/linuxcnc-dev/share/gmoccapy$ ls
images
Jim
12 years 7 months ago - 12 years 7 months ago #44680 by newbynobi
Hallo Jim,
I do not know what happened.
We will try resetting your git copy to the actual master and try again, as you will loose all your changes, please make a backup.
Please save your configs in an other directory, if you made other changes save them too.
In the following check for ERRORS!!!
Then do in a fresh terminal:
cd linuxcnc-dev git reset -- hard origin/master cd src make clean ./autogen.sh ./configure make sudo make setuid cd .. . ./scripts/rip-environment linuxcnc
And report the result.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.174 seconds
