12 years 7 months ago #44729 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Thanks Norbert, I will have a look at that.
Luminos sounds like a very interesting development. I will be looking out for it :) Let me know if you want a tester.
Regards
Marius
www.bluearccnc.com
12 years 7 months ago #44731 by cncbasher
Replied by cncbasher on topic Gmoccapy - A new screen for linuxcnc
count me in as well Norbert ,
12 years 7 months ago #44744 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
gmoccapy 1.0.8
This patch has been supplied from Steffen Noack
He added a new property to hal_gremlin to allow select the
button behavior of the mouse.
add property 'mouse_btn_mode'
0 = left rotate, middle move, right zoom
1 = left zoom, middle move, right rotate
2 = left move, middle rotate, right zoom
3 = left zoom, middle rotate, right move
4 = left move, middle zoom, right rotate
5 = left rotate, middle zoom, right move
The mouse wheel will still zoom the preview in every mode.
If you select an element in the preview, the selected element
will be taken as rotation center point.
Gremlin has as default Mode 0, I selected Mode 4 for gmoccapy as default. If you do not like that mode, just change it on the settings page. I updated the WIKI and also the translations.
Someone have to take a look on the Serbian translation, and who can check my Hobby Spanish translation. Just take gtranslator and open the corresponding files in linuxcnc-dev/src/po/gmoccapy/??.po and after editing post the file, I will push the changes.
Norbert
P.S. At the volunteers for luminos, I will come back to you.
12 years 7 months ago #44753 by mariusl
Hi Norbert
Is there a way to hide a glade panel that is inserted in the box_custom_1 space. I would only like to bring it up on the screen when I do the reference tool probe. After that it must be hidden completely until the next tool change.
Regards
Marius
www.bluearccnc.com
12 years 7 months ago #44793 by Quadro
Replied by Quadro on topic Gmoccapy - A new screen for linuxcnc
Hello Norbert,
Are you accepting any requests for features for luminos (BTW a lot better name than gmoccapy)?
Anthony
12 years 7 months ago #44794 by jbunch
Replied by jbunch on topic Gmoccapy - A new screen for linuxcnc
Norbert,
Here is the new error after runing the build.
:~/linuxcnc-dev$ linuxcnc
LINUXCNC - 2.6.0~pre
Machine configuration directory is '/home/jimbo/linuxcnc/configs/yam_lathe'
Machine configuration file is 'yam-lathe.ini'
Starting LinuxCNC...
/home/jimbo/linuxcnc-dev/scripts/realtime: line 159: /home/jimbo/linuxcnc-dev/bin/linux
cnc_module_helper: Permission denied
Realtime system did not load
Running HAL shutdown script
RTAPI: ERROR: could not open shared memory (errno=2)
/home/jimbo/linuxcnc-dev/scripts/linuxcnc: line 492: 5318 Segmentation fault $HAL
CMD -f $SHUTDOWN
/home/jimbo/linuxcnc-dev/scripts/linuxcnc: line 492: 5325 Segmentation fault $HAL
CMD stop
/home/jimbo/linuxcnc-dev/scripts/linuxcnc: line 492: 5326 Segmentation fault $HAL
CMD unload all
/home/jimbo/linuxcnc-dev/scripts/realtime: line 192: /home/jimbo/linuxcnc-dev/bin/linux
Cleanup done
LinuxCNC terminated with an error. You can find more information in the log:
/home/jimbo/linuxcnc_debug.txt
and
/home/jimbo/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Jim
Moderators: newbynobi, HansU
Time to create page: 1.953 seconds
