- mariusl
12 years 7 months ago #44843
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Just tested it, bloody amazing man. Now we can do some stuff :whistle:
This screen just gets better and better.
Regards
Marius
www.bluearccnc.com
- mariusl
12 years 7 months ago #44844
by mariusl
Regards
Marius
www.bluearccnc.com
Norbert
Do you use the workspace the same as your config directory?
Regards
Marius
www.bluearccnc.com
- newbynobi
- Thank you received: 394
12 years 7 months ago #44849
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Marius,
no, please do not use the config dir as Aptana workspace dir. Use the default in your home instead, otherwise you will get a lot of files in your linuxcnc-dev directory witch are not needed and cause only problems in case of building a patch or pushing changes.
Norbert
Norbert
- mariusl
12 years 7 months ago #44851
by mariusl
Regards
Marius
www.bluearccnc.com
Hi Norbert
Sorry for the twenty questions. Is there a way to run just this panel from the terminal or do we need the full Gmoccapy to load?
Regards
Marius
www.bluearccnc.com
- newbynobi
12 years 7 months ago #44877
by newbynobi
Halo Marius,
yes and no is the answer.
Open a terminal and start gmoccapy
open an other terminal and after also gibing rip-environment enter
gladevcp hiding_panel.glade
or
gladevcp -u hiding_panel.py hiding_panel.glade
Norbert
or
Norbert
- mariusl
12 years 7 months ago #44879
by mariusl
Regards
Marius
www.bluearccnc.com
Ahh Ok. I take it the panel that you are working on does not have to be loaded in Gmoccapy, only in the second terminal.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.435 seconds
