- Thank you received: 394
- newbynobi
Hi Norbert
I found a strange behaviour in Gmoccapy. If you go to the setup page before going to auto mode, you cannot go to auto mode again.
To explain:
Switch on machine
reset emergency
goto setup page
return from setup page by pushing the setup button again
Now no mode buttons are active.
I just tested that, I am not able to find any error. If the machine is in emergency state, not mode button are selectable, after switching on the machine, manual get active, after homing the other modes.
If I enter the setup page (not homed, estop circuit is ok machine is on) and leave setup by pushing the setup button, I get manual mode active. So from my point of view, everything is OK. I only found a problem, if you are working with NO_FORCE_HOMING, I will correct that one soon.
Are you not using home switches? If so, shame on you!
Norbert
- newbynobi
n lathe screen the following happens
I load the lathe_pawn.ngc example. After loading I press the run button and nothing happens. Now if press the pause button, the run button is disabled and the stop button is enabled. Then I press the Stop button and the run button is enabled again
If I push the run button now, the program starts.
If the program is complete it can be run again with the run button.
EDIT: I dont see a tool change dialog popup anywhere.
Does happen also only if NO_FORCE_HOMING; I will have to take a closer look on that one.
You do not see a tool change dialog, because lathe_pawn does not have any toolchange command
Norbert
- newbynobi
All the bugs you reported has been solved and the new version has been pushed.
Have fun with gmoccapy 1.0.3
Norbert
- mariusl
newbynobi wrote:
Hallo Marius,
sorry for the delay, I was quiet busy with my family and garden the last days, so I only could take a quick look with my phone. As you can see here There shouid not be such an entry in the TRAY section. Do you use master stepconf, or 2.5.3 stepconf? If master, please post a bug report in the stepconf thread, I am sure Chris will fix that very fast. I do not even search for that value, so I do not know wy glade does react the described way.
Norbert
Hi Norbert
I am surprised that you can give as much time as you do already. I am using the master branch. I have not worked with 2.5.3 for a very long time.
I agree it must be a bug and I will report it on the forum
Regards
Marius
www.bluearccnc.com
- mariusl
Regards
Marius
www.bluearccnc.com
- newbynobi
- previous changes to NO_FORCE_HOMING resulted in automatic starting from
line if a line has been selected in preview, I changed that so the line
is just preselected, but not taken in care if run is pressed. The other way
was to dangerous.
