12 years 7 months ago #45139 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I found a strange behaviour in Gmoccapy. If you go to the setup page before going to auto mode, you cannot go to auto mode again.
To explain:
Switch on machine
reset emergency
goto setup page
return from setup page by pushing the setup button again
Now no mode buttons are active.
Regards
Marius
www.bluearccnc.com
12 years 7 months ago - 12 years 7 months ago #45140 by mariusl
Hi Norbert
In lathe screen the following happens
I load the lathe_pawn.ngc example. After loading I press the run button and nothing happens. Now if press the pause button, the run button is disabled and the stop button is enabled. Then I press the Stop button and the run button is enabled again
If I push the run button now, the program starts.
If the program is complete it can be run again with the run button.
EDIT: I dont see a tool change dialog popup anywhere.
Regards
Marius
www.bluearccnc.com
Last edit: 12 years 7 months ago by mariusl.
12 years 7 months ago #45157 by jbunch
Replied by jbunch on topic Gmoccapy - A new screen for linuxcnc
Norbert,
Master
Jim
12 years 7 months ago #45173 by jbunch
Norbert,
It looks like the problem is with G96 CSS. I I add a G97 after the G96 all is good but no CSS.
Jim
12 years 7 months ago #45190 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Norbert,
Jim
May be now you understand, why I did write several times to test with a simple hand written file!!!
Nevertheless, I will test that as soon as I did get hardware.
Norbert
12 years 7 months ago #45191 by newbynobi
Hi Norbert
I did a new config again. This time as you suggested.
I used stepconf of the master branch that I am using
I copied the config from /linuxcnc/configs/ to my config directory
I put the gmoccapy display section in
And I have the long number over the screen again. I looked at the [TRAJ] section and stepconf generates the [TRAJ]MAX_LINEAR_VELOCITY. You mentioned last time that this should not exist but it does and is created by stepconf. Is it a bug in stepconf?
Hallo Marius,
sorry for the delay, I was quiet busy with my family and garden the last days, so I only could take a quick look with my phone. As you can see here There shouid not be such an entry in the TRAY section. Do you use master stepconf, or 2.5.3 stepconf? If master, please post a bug report in the stepconf thread, I am sure Chris will fix that very fast. I do not even search for that value, so I do not know wy glade does react the described way.
Norbert
Moderators: newbynobi, HansU
Time to create page: 3.164 seconds
