- Thank you received: 51
- pippin88
12 years 1 month ago - 12 years 1 month ago #51308
by pippin88
Replied by pippin88 on topic Gmoccapy - A new screen for linuxcnc
Norbert,
I really like what you have done on gmoccapy, however I want to change a few things to suit me, so I've started editing it.
I'm directly editing the following on a virtual machine:
/usr/share/gmoccapy/gmoccapy.glade
/usr/bin/gmoccapy
I can't work out one thing - how to change the icon size. I've edited /usr/bin/gmoccapy, changing 'iconsize = 48' to 'iconsize = 24' but it hasn't changed anything.
I've changed the requested height in the glade editor, which changes the button size, but the actual icons don't scale.
Other changes I've made in that file work (for example changes to error messages).
The other thing I would like to do is contribute some corrections of typos and spelling. How can I do that?
/usr/bin/gmoccapy
Last edit: 12 years 1 month ago by pippin88.
- cncbasher
- Thank you received: 202
12 years 1 month ago #51310
by cncbasher
Replied by cncbasher on topic Gmoccapy - A new screen for linuxcnc
you will need to go directly to the gmoccapy application
in the linuxcnc/bin directory , it's location depends on your installation
- newbynobi
- Thank you received: 394
12 years 1 month ago - 12 years 1 month ago #51312
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo pippin88,
you will have to shrink the images itself, as glade does not support automatic size allocation for button images.
You can just edit the size in the folder /usr/share/gmoccapy/images
It can be done with an image software like gimp or using the shell using convert. I do it very often for my fotos with a whole folder with
What will shrink all fotos in the actual folder to 640 x 480 pixel and save them with the same name in the subfolder klein witch must exist.
So if you change the button size from the actual height 56 to be 48, you will have to shrink the corresponding icon from the actual value 48 to 36.
I appreciate a lot if you like to contribute!
There are several ways you can.
1. making a patch
you will have to get the source code with git and make than the changes you like. After that you can make a patch with
The second line will just show you the information over the patch.
You can mail me the patch, I will check it and push it.
2. just make a list of the typos and corrections, I will correct the errors and push the changes
@cncbasher
You are not correctly right. If he wants to make only local changes for his use, he can do that with the files and folders he mentioned, but...
If he makes an update, all his changes are lost. So he will beter make backups after changes.
Norbert
for i in *.jpg ; do convert $i -resize 640x480 klein/$i ; done
1. making a patch
git format-patch master --stdout > gmoccapy_patch_from_pippin88.patch
git apply --stat gmoccapy_patch_from_pippin88.patch
@cncbasher
Norbert
Last edit: 12 years 1 month ago by newbynobi.
- cncbasher
12 years 1 month ago #51321
by cncbasher
yes agreed Norbert
- PKM
12 years 1 month ago #51331
by PKM
Replied by PKM on topic Gmoccapy - A new screen for linuxcnc
newbynobi
Is it possible to make the feed and speed sliders wider? It's hard to grab them by touch even on 15" display... twice wider would be perfect, I guess
- pippin88
12 years 1 month ago - 12 years 1 month ago #51340
by pippin88
Norbert,
Thank you for your help.
I am having good success customizing gmoccapy.
I am aware not to allow updates because they will overwrite my changes. I will start using git soon.
I have one problem with lathe mode: moving the gremlin display in lathe mode is disabled. Zoom works but dragging doesn't. I want to be able to drag it around (so I can zoom close and look at tool paths).
Many thanks for all your good work!
Moderators: newbynobi, HansU
Time to create page: 0.872 seconds
