- Thank you received: 202
- cncbasher
12 years 1 month ago #51355
by cncbasher
Replied by cncbasher on topic Gmoccapy - A new screen for linuxcnc
Rick ,
i'm using a usb 2 button , with wheel
Dave
Dave
- Andreas_S
12 years 1 month ago #51365
by Andreas_S
Replied by Andreas_S on topic Gmoccapy - A new screen for linuxcnc
Hello
I use Gmoccapy since a few weeks on my mill. Before i used Axis and therefore I'm now missed the posibilty to Switch with the keyboard to MDI and MANUAL mode.
Now I implemented in gmoccapy.py (2.7~pre) to switch to manual mode with "F3" and to MDI mode with "F5" (as in Axis) and it works fine.
Is it possible to implement the code in next release, so it wouldn't be overwritten any time I do a upgrade?
I implented it after this lines:
and here is the code:
Or what other possibilies exist to implement the code in the stable release? I'm not really familiar with software maintenace on Linux....
Andreas
try:
if keyname == "F2" and signal:
# only turn on if no estop!
if self.widgets.tbtn_estop.get_active():
return True
self.widgets.tbtn_on.emit("clicked")
return True
# Added support for F3 (manual mode) and (mdi mode)
if keyname == "F3" and signal:
self.command.mode(linuxcnc.MODE_MANUAL)
return True
if keyname == "F5" and signal:
self.command.mode(linuxcnc.MODE_MDI)
return True
Andreas
- DaBit
- Thank you received: 19
12 years 1 month ago #51655
by DaBit
Replied by DaBit on topic Gmoccapy - A new screen for linuxcnc
I have two questions. Maybe they are already answered, but I could not find it:
1) If I hit a limit switch gmoccapy nicely says I did so and shuts down the machine. The problem is that I cannot re-activate the machine since the 'override limits' checkbox stays grayed out. How can I activate that checkbox?
2) Is it possible to reduce the precision of the DRO to 2 digits behind the dot? I am running in millimeters and my feedback position comes from linear scales which I assigned a small deadband. So if I say 'G90G0X5' the DRO often displays 4.998 or so. I would prefer to have that rounded and displayed as 5.00. Where can I change that?
I am running a recent git pull of master (2.7.0~pre) BTW.
- newbynobi
- Thank you received: 394
12 years 1 month ago - 12 years 1 month ago #51673
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@All,
Sorry for being away so long. I have been working on the documentation. It is now included in master and 2.6, not completely finished, but we will soon be able to remove the Wiki side. If you like to help, please see
Linuxcnc-devel/docs/src/gui/gmoccapy.txt
It is an asciidoc fotmated text file. You can edit it and send the changes and additons by mail, so I can push them.
@Dave and Rick,
Is moving the plot in lathe mode solved? It is working here with mouse and Debian and with Touchscreen and Ubuntu.
@Andreas,
Your solution do work, but what happen if a User hits F2 , while the machine is processing a ngc file in Auto mode? We should include tests like OK for manual mode and OK for Mdi. I will try to take a closer look ASAP.
@DaBit,
If the machine is out of emergency status and the machine is off, the chk_ignore_limits should be checkable. It will be unsensitive if machine is switched on! So check the box, before switching on the machine.
You will have to edit the combi_dro settings in the gmoccapy.glade file to change the resolution of the DRO. You can do that with the glade editor. If you are on Ubuntu you may need to start glade from a terminal after doing rip-environment. (Ask if you need more info)
@pippin88
Waiting for your corrections:-)
Norbert
@Dave and Rick,
@Andreas,
@DaBit,
@pippin88
Norbert
Last edit: 12 years 1 month ago by newbynobi. Reason: added more info
- cncbasher
12 years 1 month ago #51681
by cncbasher
@norbert
being able to move plot in lathe mode does not work here , but works fine in Mill
using :
gmoccapy 1.2.2
wheezy hybrid iso & developer version from git
Also installed version
gmocappy 1.2.0 & linuxcnc 2.6.3 identical results
hope it helps
using :
gmoccapy 1.2.2
hope it helps
- pippin88
- Thank you received: 51
12 years 1 month ago #51682
by pippin88
Replied by pippin88 on topic Gmoccapy - A new screen for linuxcnc
I found that if I changed 'Mouse Button Mode' in settings it started to work.
Norbet,
I have made many changes to the GUI looks. I have customised it for mouse control (not touch screen).
It still needs a lot of work.
I'm not sure if my changes will be useful to you, but I will post them when I have things more refined.
Norbet,
Moderators: newbynobi, HansU
Time to create page: 0.407 seconds
