- bossboss
12 years 3 weeks ago #51923
by bossboss
Replied by bossboss on topic Gmoccapy - A new screen for linuxcnc
hi,
I have problems installing the camview unter debian wheezy. In your wiki there is a link to " psha.org.ru/debian/README.html ". It is a repository for Ubuntu. How to intall camview under Wheezy?
This was not a help: " wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding_Camview "
thanks!
thanks!
- newbynobi
- Thank you received: 394
12 years 3 weeks ago #51930
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Sorry, i am not able to help, i only offer the place to include other programs. May even be necessary to build from souce.
psha.org.ru/b/camview-emc.html
I did read somewhere that it has been included, but i can't find it anymore.
Norbert
Norbert
- Thank you received: 2181
12 years 3 weeks ago #51933
Yes the hal_sourceview code has search capability, adding replace should not be that hard... I will try to look at that soon.
Chris M
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
newbynobi wrote: @papaours
It should be possible, and I realy like that idea!2: could it be possible in the gcode editor to ad the option REPLACE wich is very helpfull when you need to change a Z value.
Chris: Could you give us a hand on that, as the original code comes from you.
Norbert
Chris M
12 years 2 weeks ago #51973
Norbert:
I added a text_replace method to the hal_sourceview widget in master.
You can replace-all and ignore-case as options.
I added the capability to Gscreen industrial as an example.
You will need to add buttons and code to use it in Gmoccapy of course.
Chris M
Chris M
- newbynobi
12 years 2 weeks ago - 12 years 2 weeks ago #51981
by newbynobi
gmoccapy 1.3.0 - added replace to edit mode
ver. 1.3.0
- added replace function to the edit page
- added ignore case to allow case sensitive search
- added reload button on edit page, so if you
mixed up to much, you are able to reload the
original file
- corrected an error at start up, giving a button
a label, conflicting with a button label
- changed a wrong icon on the button go up one directory
1.3.0 is only in master!! as the replace functions of hal_sourceview are not yet in 2.6 !!
Next I will try to make the keyboard shortcuts editable or at least allow users to add additional keys.
Norbert
ver. 1.3.0
original file
Norbert
Last edit: 12 years 2 weeks ago by newbynobi.
The following user(s) said Thank You: balestrino
- LAIR82
12 years 2 weeks ago #52017
by LAIR82
Replied by LAIR82 on topic Gmoccapy - A new screen for linuxcnc
Hello Guys,
My operator has noticed an issue on two of the three machines that are using gmoccapy, friday he was running a small production job on the one turning center and noticed the following,
He was running a fairly long program, but the first section, probably 20-25 lines was a small chamfer, turn the OD to a shoulder, then face the shoulder, then return to tool change position, holding on an M01. He would check the od with a Micrometer, then run a spring-pass if needed to take another tenth or two off the OD. The problem was if he needed to take the spring-pass he would press program stop, then press program start, and the machine would not start at the top of the program, it would start moving at a feed rate not the rapid to the start position. I ran it a few times, and noticed it every time. After it would start up funky like that, then we would hit program stop, then program start, and it would run fine. But it will always run one messed up cycle, then be fine when doing this.
Rick
Rick
Moderators: newbynobi, HansU
Time to create page: 0.649 seconds
