DO NOT EXTRACT...Transistor wrote: Hi, Fern.
I can't seem to get this to work. I started again and had AXIS running properly. Here's what I did next:
- Extract NativeCAM download to my home folder. This will install a folder NativeCAM-master.
NEVER USE 'sudo' with ncam.py, it will create directories where you only have read permissionsTransistor wrote: - For some reason the unzip creates ~/NativeCAM-master/NativeCAM-master/. I moved the inner one up to ~/ to keep the file paths shorter.
- Go to ~/NativeCAM-master and double-click on ncam.py. It will install the NativeCAM application in standalone mode and open it up.
- Open a Terminal window.Code:cd ~/NativeCAM-master sudo ./ncam.py -i ~/PathTo/MyMillIniFileName.ini -c mill
Done + a few more that I found.From '/home/cnc1/linuxcnc/configs/ia-mill/ncam' delete 'cfg', 'graphics' and 'lib' subdirs/links
