NativeCAM is Features renamed
9 years 4 months ago #95155 by FernV
Replied by FernV on topic NativeCAM is Features renamed
Hi Floris,
On next update, you will have to edit Preferences and check this box
Fern
The following user(s) said Thank You: eFalegname
9 years 4 months ago #95163 by eFalegname
Hi Fern, I'm trying to engrave some text and maybe I miss some dependences or, should I make some setting before run the text engraving function? The same issue I have with the text engraving example. Could you take a look please?
Floris
9 years 4 months ago #95170 by FernV
HI Floris,
I can not find the meaning of this 255 code.
Check that truetype-tracer package is installed and also the font you want to use.
truetype-tracer should usually be installed with LinuxCNC
I checked the example and it seems it was not updated with the latest changes,
you could have an error because it can not do a G1 with a feed of 0. This is just for the example.
Fern
P.S. A simple reminder that if you always want "Tool length compensation " to be "No",
you can set and save all "Tool Change" values as custom default using
9 years 4 months ago - 9 years 4 months ago #95178 by eFalegname
Thanks Fern for your tip, I have saved my defaults values and then hid coolant compensation and tool length functions.
The installation of true-type tracer solved my problem with the engraving fonts, but in the example of the project the error of G1 without Feedrate persists.
It would be nice to add a 45 and 90 degree hatch option to the engraving function.
Are you planning to implement tool wear compensation, maybe G41.1 D#; G42.1 D# for simplicity? I could not live without dynamic compensation.
Imho a calculator is more useful than a simple virtual keyboard.
In the rectangle function, you should increase the corner options as in the image bellow please, cnc router's users will be very grateful.
Sorry for the long list of wishes, is that I'm very enthusiastic about your work.
My eternal gratitude.
Floris
Note: I don't see any updates for debian stretch.
Last edit: 9 years 4 months ago by eFalegname.
9 years 4 months ago #95184 by FernV
eFalegname wrote: ...I have saved my defaults values and then hid coolant compensation and tool length functions.
Hidden state is saved with custom defaults values so hide before saving. You do not have to delete those before saving again
eFalegname wrote: ...It would be nice to add a 45 and 90 degree hatch option to the engraving function.
ncam calls truetype-tracer which is the work of Chris Radek and others from a python script. truetype-tracer is compiled for different os versions and I have no plans now to create a new tt-tracer
eFalegname wrote: ...Are you planning to implement tool wear compensation, maybe G41.1 D#; G42.1 D# for simplicity?
I will consider your suggestion
eFalegname wrote: ...Imho a calculator is more useful than a simple virtual keyboard.
I agree
eFalegname wrote: ...In the rectangle function, you should increase the corner options as in the image bellow
I will also consider this suggestion
eFalegname wrote: ...Sorry for the long list of wishes, is that I'm very enthusiastic about your work.
PLEASE, DO NOT STOP REQUESTING NEW FEATURES
eFalegname wrote: ...I don't see any updates for debian stretch.
Update of NativeCAM on your system will be automatic AFTER a new version is pushed
Fern
9 years 4 months ago - 9 years 4 months ago #95202 by eFalegname
Fern
Hi Fern,
on a wood router cnc cabinet parts have to be left side and right, for that reason a mirror feature is very important, a sort of G50-G51 Gcode in mach3 not implemented in linuxcnc. Under the Group "Offset-Rotation" could you add a Mirror toolpath function maybe flipping and shifting the current workoffset (not rotating it) and not reversing the toolpaths to mantain the same milling direction?
forum.linuxcnc.org/40-subroutines-and-ng...-mirror?limitstart=0
Cheers,
Floris
Time to create page: 0.298 seconds
