- Thank you received: 486
NativeCAM is Features renamed
9 years 4 months ago #95217
by Clive S
I was trying to run this not embedded ie stand alone. I achieved this (incorrectly it seems) by commenting out the Glade line in the ini file this seemed to work fine but I was wrong.
When I try with NativeCAM embedded everything is OK
So can you please inform me the correct way to run it as stand alone. Thanks
Replied by Clive S on topic NativeCAM is Features renamed
Fern sorry you lead you astray. I think I have been doing things incorrect.FernV wrote:
Do you really mean that even with metric in TRAJ you get a G20 ???Clive s wrote: ...I have metric in the TRAJ ini I do have G21 to the preamble under preferences
I forgot to mention this is with master 2.8 build
This is not affected by lcnc versions. The only reference is TRAJ section unless no inifile is specified then it defaults to imperial
Fern
9 years 4 months ago #95218
by FernV
Replied by FernV on topic NativeCAM is Features renamed
Clive,
This how metric is identified, it must be either 'mm' or 'metric'
Fern
default_metric = ini_instance.find('TRAJ', 'LINEAR_UNITS') in ['mm', 'metric']
Fern
9 years 4 months ago - 9 years 4 months ago #95219
by FernV
Easy,
$ ncam -i inifilename
Same inifile loaded by lcnc
Fern
Clive s wrote: ...can you please inform me the correct way to run it as stand alone.
Easy,
Fern
Last edit: 9 years 4 months ago by FernV. Reason: removed ( and )
- eFalegname
- Thank you received: 30
9 years 4 months ago - 9 years 4 months ago #95220
by eFalegname
Replied by eFalegname on topic NativeCAM is Features renamed
Hi Fern I'm very excited with the news, but I still have not been able to download the updates, I have this error I don't know if it could be a network error or not:
W: Download is performed unsandboxed as root as file '/root/.synaptic/tmp//tmp_sh' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permesso negato)
W: Errore nello scaricare packagecloud.io/FernV/NativeCAM/debian/p...ivecam_0.1.4_all.deb
Operation timed out after 120001 milliseconds with 0 out of 0 bytes received
denied permission and downloading error...
Any idea?
Floris
Any idea?
Floris
Last edit: 9 years 4 months ago by eFalegname.
9 years 4 months ago #95221
by FernV
I was able to download the deb by simply clicking the link you supplied, but ...
Updates should be automatic.
If you open synaptic, find nativecam and check for updates, what does happen ? Could it be updated this way ?
Fern
Fern
- eFalegname
9 years 4 months ago #95223
by eFalegname
It was just a message from synaptic, I waited a while and eventually downloaded the updates, it seems a network error.
The last % symbol should be written at the end of the program and not along the post-amble, you have to move it to the bottom otherwise it will not work.
Then with regard to G41.1; G42.1 I have to do some milling test since according to the simulation the tool wear compensation does not turn out work ok, for better understanding I'll make a video and post the results later.
Thanks for your promptness
Floris
Floris
Time to create page: 0.117 seconds
