- Thank you received: 30
NativeCAM is Features renamed
- eFalegname
9 years 4 months ago - 9 years 4 months ago #95115
by eFalegname
Replied by eFalegname on topic NativeCAM is Features renamed
Hi Fern,
I'm having some problems with my tool change, I still do not understand how manual tool change works in NativeCam, maybe I have to delete all my previous tool change configuration, Could you clarify my doubt, please?
here you have my ini file:
Thank you!
Thank you!
Last edit: 9 years 4 months ago by eFalegname.
- eFalegname
9 years 4 months ago - 9 years 4 months ago #95117
by eFalegname
Then I also would need a helping hand regarding implementation of % to wrap the Gcode, so I have a small list of wishes :laugh: :laugh: ....
9 years 4 months ago #95118
by FernV
There is no special way to use manual tool change with NativeCAM, it is standard LinuxCNC
I looked at your ini file and there are lot of options I see for the first time, I would certainly have to disable many to use it.
Could you explain more about 'problems with my tool change'
What do you mean by 'wrapping the code', what code do you want to wrap with what code ?
Fern
Replied by FernV on topic NativeCAM is Features renamed
eFalegname wrote: Hi Fern,
Fern
- eFalegname
9 years 4 months ago - 9 years 4 months ago #95120
by eFalegname
Since I find difficult to explain it in English I copied and pasted from the linuxcnc manual what I mean with wraping the Gcode:
Ex. of my Gcode :
I don't use any M2 or M30 to finish my Gcode in order to not change the current Work Offset or restore G54
20. File Requirements
A G code file must contain one or more lines of G code and be terminated with a Program End. Any G code past the program end is not evaluated.
If a program end code is not used a pair of percent signs % with the first percent sign on the first line of the file followed by one or more lines of G code and a second percent sign. Any code past the second percent sign is not evaluated.
Warning
Using % to wrap a G code file will not do the same thing as using a program end. The machine will be in what ever state the program left it in using %, the spindle and coolant may still be on and things like G90/91 are left as the last program set them. If you don’t use a proper preamble the next program could start in a dangerous condition.
Note
The file must be created with a text editor like Gedit and not a word processor like Open Office Word Processor.
9 years 4 months ago #95123
by FernV
The gcode file is auto-generated with pre-amble and post-amble by NativeCAM every time you make a change. You can create pretty complex parts by selecting basic or advanced shapes and other options without writing a line of gcode yourself.
If it can not do what you want, you can add custom code or file (see in Miscelaneous). You do not write the whole file but only what ncam can not do. Your custom code or custom file is inserted at the position you defined.
There is a learning curve to write gcode and my plan is to add more features.
Play with it in the simulator and even mill some parts.
Fern
Fern
- eFalegname
9 years 4 months ago - 9 years 4 months ago #95124
by eFalegname
I have two plates. The fixed plate on the worktop serves to refer the first tool by setting its length equal to zero, after the NativeCam installation the tool doesn't go to the fixed plate anymore:
Time to create page: 0.097 seconds
