Reliable USB WiFi?
01 Nov 2017 09:22 #101135 by PCW
Replied by PCW on topic Reliable USB WiFi?
If you do have a wired connection available, you can just add a
USB<-->Ethernet dongle for the general purpose network interface
01 Nov 2017 09:23 #101136 by tecno
Replied by tecno on topic Reliable USB WiFi?
Yes I know but I am on a very low budget here on my pension so I will have to try all options I have in house.
03 Nov 2017 03:35 - 03 Nov 2017 03:35 #101214 by tecno
A friend of mine had one with him yesterday for me to test, lsusb will not see this USB2LAN adapter at all as was with new modern USB WiFi dongles.
So it looks like I will have to use wired connection when needed for updates etc in future.
Last edit: 03 Nov 2017 03:35 by tecno.
  • deceased
  • deceased's Avatar
  • Visitor
  • Visitor
03 Nov 2017 03:41 #101217 by deceased
Replied by deceased on topic Reliable USB WiFi?
To really see what is going on you need to check the output of dmesg after plugging the device in.
Saying linux does not "see" a device is lacking information. A manufacturer\model FCCID can help with initial problem solving.
Just because USB wifi does not connect does not mean it's an issue with Linux.....it could be a config issue, that's why the output of dmesg is very important.
03 Nov 2017 03:43 #101218 by tecno
Problem is that dmesg fails
  • deceased
  • deceased's Avatar
  • Visitor
  • Visitor
03 Nov 2017 03:44 #101219 by deceased
In what way ?
That's bad.
03 Nov 2017 03:46 #101220 by tecno
I have Linux installed with Swedish settings, so I will go down shortly to my workshop and copy that message and write from down there.
BRB
03 Nov 2017 03:53 #101221 by tecno
bengt@CNC3000:~$ dmesg
dmesg: läsning av kärnbuffert misslyckades: Operationen inte tillåten
bengt@CNC3000:~$
translation= read of kernel buffer failed : operation not allowed /// or something like that
  • deceased
  • deceased's Avatar
  • Visitor
  • Visitor
03 Nov 2017 03:58 #101222 by deceased
have you tried
sudo dmesg
03 Nov 2017 04:01 #101223 by tecno
bengt@CNC3000:~$ sudo dmesg
[sudo] lösenord för bengt:
[    0.000000] Linux version 4.9.0-3-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #1 SMP PREEMPT RT Debian 4.9.30-2+deb9u2 (2017-06-26)
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] x86/fpu: Using 'eager' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f3ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f400-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007f68ffff] usable
[    0.000000] BIOS-e820: [mem 0x000000007f690000-0x000000007f6dffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007f6e0000-0x000000007f6e2fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000007f6e3000-0x000000007f6effff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000007f6f0000-0x000000007f6fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000ffffffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.2 present.
[    0.000000] DMI:    /LakePort, BIOS 6.00 PG 11/19/2008
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x7f690 max_arch_pfn = 0x1000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-C9FFF write-protect
[    0.000000]   CA000-F7FFF uncachable
[    0.000000]   F8000-FBFFF write-through
[    0.000000]   FC000-FFFFF uncachable
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask 080000000 write-back
[    0.000000]   1 base 07F800000 mask 0FF800000 uncachable
[    0.000000]   2 base 07F700000 mask 0FFF00000 uncachable
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] found SMP MP-table at [mem 0x000f3d40-0x000f3d4f] mapped at [c00f3d40]
[    0.000000] initial memory mapped: [mem 0x00000000-0x11dfffff]
[    0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[    0.000000] BRK [0x11a58000, 0x11a58fff] PGTABLE
[    0.000000] BRK [0x11a59000, 0x11a5afff] PGTABLE
[    0.000000] BRK [0x11a5b000, 0x11a5bfff] PGTABLE
[    0.000000] BRK [0x11a5c000, 0x11a5cfff] PGTABLE
[    0.000000] RAMDISK: [mem 0x35cff000-0x36e76fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F7FE0 000014 (v00 IntelR)
[    0.000000] ACPI: RSDT 0x000000007F6E3000 000030 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: FACP 0x000000007F6E3080 000074 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: DSDT 0x000000007F6E3100 004426 (v01 INTELR AWRDACPI 00001000 MSFT 03000000)
[    0.000000] ACPI: FACS 0x000000007F6E0000 000040
[    0.000000] ACPI: MCFG 0x000000007F6E7600 00003C (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: APIC 0x000000007F6E7540 000084 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 1148MB HIGHMEM available.
[    0.000000] 889MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 379fe000
[    0.000000]   low ram: 0 - 379fe000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   Normal   [mem 0x0000000001000000-0x00000000379fdfff]
[    0.000000]   HighMem  [mem 0x00000000379fe000-0x000000007f68ffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000007f68ffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000007f68ffff]
[    0.000000] On node 0 totalpages: 521774
[    0.000000] free_area_init_node: node 0, pgdat d1814000, node_mem_map f4913028
[    0.000000]   DMA zone: 40 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   Normal zone: 2185 pages used for memmap
[    0.000000]   Normal zone: 223742 pages, LIFO batch:31
[    0.000000]   HighMem zone: 294034 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] Reserving Intel graphics memory at 0x000000007f800000-0x000000007fffffff
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000effff]
[    0.000000] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
[    0.000000] e820: [mem 0x80000000-0xdfffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] percpu: Embedded 101 pages/cpu @f7867000 s381216 r0 d32480 u413696
[    0.000000] pcpu-alloc: s381216 r0 d32480 u413696 alloc=101*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 519549
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-3-rt-686-pae root=UUID=ef18c43d-9e90-4481-826c-a53ae788db66 ro quiet
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] microcode: microcode updated early to revision 0x218, date = 2009-04-10
[    0.000000] Initializing CPU#0
[    0.000000] Initializing HighMem for node 0 (000379fe:0007f690)
[    0.000000] Initializing Movable for node 0 (00000000:00000000)
[    0.000000] Memory: 2035196K/2087096K available (5968K kernel code, 622K rwdata, 1744K rodata, 1052K init, 592K bss, 51900K reserved, 0K cma-reserved, 1176136K highmem)
[    0.000000] virtual kernel memory layout:
                   fixmap  : 0xffd36000 - 0xfffff000   (2852 kB)
                   pkmap   : 0xffa00000 - 0xffc00000   (2048 kB)
                   vmalloc : 0xf81fe000 - 0xff9fe000   ( 120 MB)
                   lowmem  : 0xc0000000 - 0xf79fe000   ( 889 MB)
                     .init : 0xd1827000 - 0xd192e000   (1052 kB)
                     .data : 0xd15d44fa - 0xd1825840   (2372 kB)
                     .text : 0xd1000000 - 0xd15d44fa   (5969 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=4.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS:2304 nr_irqs:456 16
[    0.000000] CPU 0 irqstacks, hard=f703e000 soft=f7080000
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 1600.043 MHz processor
[    0.004010] Calibrating delay loop (skipped), value calculated using timer frequency.. 3200.08 BogoMIPS (lpj=6400172)
[    0.004013] pid_max: default: 32768 minimum: 301
[    0.004074] ACPI: Core revision 20160831
[    0.013960] ACPI: 1 ACPI AML tables successfully acquired and loaded
[    0.014043] Security Framework initialized
[    0.014046] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.014058] AppArmor: AppArmor disabled by boot time parameter
[    0.014095] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.014100] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.014819] CPU: Physical Processor ID: 0
[    0.014822] CPU: Processor Core ID: 0
[    0.014829] mce: CPU supports 5 MCE banks
[    0.014842] CPU0: Thermal monitoring enabled (TM1)
[    0.014852] process: using mwait in idle threads
[    0.014866] Last level iTLB entries: 4KB 32, 2MB 0, 4MB 0
[    0.014868] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 8, 1GB 0
[    0.015225] Freeing SMP alternatives memory: 24K (d192e000 - d1934000)
[    0.020015] ftrace: allocating 23979 entries in 47 pages
[    0.036250] smpboot: Max logical packages: 4
[    0.036266] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.036705] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.080000] smpboot: CPU0: Intel(R) Atom(TM) CPU  230   @ 1.60GHz (family: 0x6, model: 0x1c, stepping: 0x2)
[    0.080000] Performance Events: PEBS fmt0+, LBR disabled due to erratumAtom events, Intel PMU driver.
[    0.080000] ... version:                3
[    0.080000] ... bit width:              40
[    0.080000] ... generic registers:      2
[    0.080000] ... value mask:             000000ffffffffff
[    0.080000] ... max period:             000000007fffffff
[    0.080000] ... fixed-purpose events:   3
[    0.080000] ... event mask:             0000000700000003
[    0.132362] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.184079] CPU 1 irqstacks, hard=f71cc000 soft=f71ce000
[    0.184084] x86: Booting SMP configuration:
[    0.184090] .... node  #0, CPUs:      #1
[    0.008000] Initializing CPU#1
[    0.266071] x86: Booted up 1 node, 2 CPUs
[    0.266071] smpboot: Total of 2 processors activated (6400.19 BogoMIPS)
[    0.266071] devtmpfs: initialized
[    0.268067] PM: Registering ACPI NVS region [mem 0x7f6e0000-0x7f6e2fff] (12288 bytes)
[    0.268067] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.268067] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.268067] pinctrl core: initialized pinctrl subsystem
[    0.268067] NET: Registered protocol family 16
[    0.272051] cpuidle: using governor ladder
[    0.276038] cpuidle: using governor menu
[    0.276133] ACPI: bus type PCI registered
[    0.276141] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.276371] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.276375] PCI: Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub with MMCONFIG support
[    0.276384] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.276386] PCI: Using MMCONFIG for extended config space
[    0.276389] PCI: Using configuration type 1 for base access
[    0.280278] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.280278] ACPI: Added _OSI(Module Device)
[    0.280278] ACPI: Added _OSI(Processor Device)
[    0.280278] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.280282] ACPI: Added _OSI(Processor Aggregator Device)
[    0.290553] ACPI: Interpreter enabled
[    0.290616] ACPI: (supports S0 S1 S4 S5)
[    0.290620] ACPI: Using IOAPIC for interrupt routing
[    0.290713] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.309437] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.309454] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.309470] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[    0.310372] PCI host bridge to bus 0000:00
[    0.310383] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.310389] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.310395] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.310400] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.310406] pci_bus 0000:00: root bus resource [mem 0x7f750000-0xfebfffff window]
[    0.310413] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.310437] pci 0000:00:00.0: [8086:2770] type 00 class 0x060000
[    0.310816] pci 0000:00:02.0: [8086:2772] type 00 class 0x030000
[    0.310838] pci 0000:00:02.0: reg 0x10: [mem 0xfdf00000-0xfdf7ffff]
[    0.310850] pci 0000:00:02.0: reg 0x14: [io  0xff00-0xff07]
[    0.310862] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff pref]
[    0.310873] pci 0000:00:02.0: reg 0x1c: [mem 0xfdf80000-0xfdfbffff]
[    0.311266] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[    0.311385] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.311582] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.311776] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[    0.311892] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.312129] pci 0000:00:1c.1: System wakeup disabled by ACPI
[    0.312328] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[    0.312387] pci 0000:00:1d.0: reg 0x20: [io  0xfe00-0xfe1f]
[    0.312606] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.312787] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[    0.312845] pci 0000:00:1d.1: reg 0x20: [io  0xfd00-0xfd1f]
[    0.313063] pci 0000:00:1d.1: System wakeup disabled by ACPI
[    0.313253] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[    0.313311] pci 0000:00:1d.2: reg 0x20: [io  0xfc00-0xfc1f]
[    0.313535] pci 0000:00:1d.2: System wakeup disabled by ACPI
[    0.313727] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[    0.313785] pci 0000:00:1d.3: reg 0x20: [io  0xfb00-0xfb1f]
[    0.314029] pci 0000:00:1d.3: System wakeup disabled by ACPI
[    0.314230] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[    0.314259] pci 0000:00:1d.7: reg 0x10: [mem 0xfdfff000-0xfdfff3ff]
[    0.314376] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.314562] pci 0000:00:1d.7: System wakeup disabled by ACPI
[    0.314746] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.314998] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.315194] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[    0.315320] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[    0.315336] pci 0000:00:1f.0: quirk: [io  0x0400-0x047f] claimed by ICH6 ACPI/GPIO/TCO
[    0.315346] pci 0000:00:1f.0: quirk: [io  0x0480-0x04bf] claimed by ICH6 GPIO
[    0.315355] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0294 (mask 0003)
[    0.315728] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x010180
[    0.315751] pci 0000:00:1f.2: reg 0x10: [io  0x0000-0x0007]
[    0.315765] pci 0000:00:1f.2: reg 0x14: [io  0x0000-0x0003]
[    0.315778] pci 0000:00:1f.2: reg 0x18: [io  0x0000-0x0007]
[    0.315791] pci 0000:00:1f.2: reg 0x1c: [io  0x0000-0x0003]
[    0.315805] pci 0000:00:1f.2: reg 0x20: [io  0xf800-0xf80f]
[    0.315830] pci 0000:00:1f.2: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
[    0.315834] pci 0000:00:1f.2: legacy IDE quirk: reg 0x14: [io  0x03f6]
[    0.315839] pci 0000:00:1f.2: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
[    0.315844] pci 0000:00:1f.2: legacy IDE quirk: reg 0x1c: [io  0x0376]
[    0.315886] pci 0000:00:1f.2: PME# supported from D3hot
[    0.316290] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[    0.316359] pci 0000:00:1f.3: reg 0x20: [io  0x0500-0x051f]
[    0.316859] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.316867] pci 0000:00:1c.0:   bridge window [io  0xc000-0xcfff]
[    0.316875] pci 0000:00:1c.0:   bridge window [mem 0xfdd00000-0xfddfffff]
[    0.316885] pci 0000:00:1c.0:   bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[    0.317047] pci 0000:02:00.0: [10ec:8136] type 00 class 0x020000
[    0.317080] pci 0000:02:00.0: reg 0x10: [io  0xbe00-0xbeff]
[    0.317119] pci 0000:02:00.0: reg 0x18: [mem 0xfdeff000-0xfdefffff 64bit pref]
[    0.317144] pci 0000:02:00.0: reg 0x20: [mem 0xfdee0000-0xfdeeffff 64bit pref]
[    0.317163] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[    0.317282] pci 0000:02:00.0: supports D1 D2
[    0.317287] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.328029] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.328039] pci 0000:00:1c.1:   bridge window [io  0xb000-0xbfff]
[    0.328047] pci 0000:00:1c.1:   bridge window [mem 0xfd900000-0xfd9fffff]
[    0.328057] pci 0000:00:1c.1:   bridge window [mem 0xfde00000-0xfdefffff 64bit pref]
[    0.328238] pci 0000:00:1e.0: PCI bridge to [bus 03] (subtractive decode)
[    0.328247] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
[    0.328254] pci 0000:00:1e.0:   bridge window [mem 0xfdc00000-0xfdcfffff]
[    0.328264] pci 0000:00:1e.0:   bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.328270] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.328275] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.328281] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.328286] pci 0000:00:1e.0:   bridge window [mem 0x000c0000-0x000dffff window] (subtractive decode)
[    0.328291] pci 0000:00:1e.0:   bridge window [mem 0x7f750000-0xfebfffff window] (subtractive decode)
[    0.328318] pci_bus 0000:00: on NUMA node 0
[    0.332877] ACPI: PCI Interrupt Link [LNKA] (IRQs *5 7 9 10 11 12 14 15)
[    0.333096] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 7 9 *10 11 12 14 15)
[    0.333310] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 7 9 *10 11 12 14 15)
[    0.333523] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 7 9 10 *11 12 14 15)
[    0.333739] ACPI: PCI Interrupt Link [LNKE] (IRQs 5 7 *9 10 11 12 14 15)
[    0.333951] ACPI: PCI Interrupt Link [LNKF] (IRQs 5 7 9 10 11 12 14 15) *0, disabled.
[    0.334195] ACPI: PCI Interrupt Link [LNK0] (IRQs 5 7 9 10 11 12 14 15) *0, disabled.
[    0.334414] ACPI: PCI Interrupt Link [LNK1] (IRQs 5 7 9 10 *11 12 14 15)
[    0.334810] ACPI: Enabled 2 GPEs in block 00 to 1F
[    0.335325] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.335325] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.335325] vgaarb: loaded
[    0.335325] vgaarb: bridge control possible 0000:00:02.0
[    0.335325] PCI: Using ACPI for IRQ routing
[    0.343454] PCI: pci_cache_line_size set to 64 bytes
[    0.343536] e820: reserve RAM buffer [mem 0x0009f400-0x0009ffff]
[    0.343543] e820: reserve RAM buffer [mem 0x7f690000-0x7fffffff]
[    0.344505] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.344520] hpet clockevent registered
[    0.344529] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[    0.344537] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.344550] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[    0.346618] clocksource: Switched to clocksource hpet
[    0.389893] VFS: Disk quotas dquot_6.6.0
[    0.389957] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.390321] pnp: PnP ACPI init
[    0.390905] system 00:00: [io  0x04d0-0x04d1] has been reserved
[    0.390913] system 00:00: [io  0x0290-0x029f] has been reserved
[    0.390921] system 00:00: [io  0x0800-0x0805] has been reserved
[    0.390927] system 00:00: [io  0x0290-0x0297] has been reserved
[    0.390934] system 00:00: [io  0x0880-0x088f] has been reserved
[    0.390947] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.391113] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.391990] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.392848] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.393746] system 00:04: [io  0x0400-0x04bf] could not be reserved
[    0.393761] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.394547] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[    0.394560] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.394941] system 00:06: [mem 0x000f0000-0x000fffff] could not be reserved
[    0.394950] system 00:06: [mem 0x7f6e0000-0x7f6fffff] could not be reserved
[    0.394957] system 00:06: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.394963] system 00:06: [mem 0x00100000-0x7f6dffff] could not be reserved
[    0.394970] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.394977] system 00:06: [mem 0xfed13000-0xfed1dfff] has been reserved
[    0.394984] system 00:06: [mem 0xfed20000-0xfed8ffff] has been reserved
[    0.394991] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.394997] system 00:06: [mem 0xffb00000-0xffb7ffff] has been reserved
[    0.395004] system 00:06: [mem 0xfff00000-0xffffffff] has been reserved
[    0.395011] system 00:06: [mem 0x000e0000-0x000effff] has been reserved
[    0.395022] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.395048] pnp: PnP ACPI: found 7 devices
[    0.395056] PnPBIOS: Disabled
[    0.440510] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.440581] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.440589] pci 0000:00:1c.0:   bridge window [io  0xc000-0xcfff]
[    0.440599] pci 0000:00:1c.0:   bridge window [mem 0xfdd00000-0xfddfffff]
[    0.440607] pci 0000:00:1c.0:   bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[    0.440629] pci 0000:02:00.0: BAR 6: assigned [mem 0xfd900000-0xfd91ffff pref]
[    0.440635] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.440642] pci 0000:00:1c.1:   bridge window [io  0xb000-0xbfff]
[    0.440650] pci 0000:00:1c.1:   bridge window [mem 0xfd900000-0xfd9fffff]
[    0.440658] pci 0000:00:1c.1:   bridge window [mem 0xfde00000-0xfdefffff 64bit pref]
[    0.440669] pci 0000:00:1e.0: PCI bridge to [bus 03]
[    0.440675] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
[    0.440684] pci 0000:00:1e.0:   bridge window [mem 0xfdc00000-0xfdcfffff]
[    0.440691] pci 0000:00:1e.0:   bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.440703] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.440709] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.440714] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.440720] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff window]
[    0.440725] pci_bus 0000:00: resource 8 [mem 0x7f750000-0xfebfffff window]
[    0.440731] pci_bus 0000:01: resource 0 [io  0xc000-0xcfff]
[    0.440736] pci_bus 0000:01: resource 1 [mem 0xfdd00000-0xfddfffff]
[    0.440741] pci_bus 0000:01: resource 2 [mem 0xfda00000-0xfdafffff 64bit pref]
[    0.440746] pci_bus 0000:02: resource 0 [io  0xb000-0xbfff]
[    0.440752] pci_bus 0000:02: resource 1 [mem 0xfd900000-0xfd9fffff]
[    0.440757] pci_bus 0000:02: resource 2 [mem 0xfde00000-0xfdefffff 64bit pref]
[    0.440762] pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
[    0.440768] pci_bus 0000:03: resource 1 [mem 0xfdc00000-0xfdcfffff]
[    0.440773] pci_bus 0000:03: resource 2 [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.440778] pci_bus 0000:03: resource 4 [io  0x0000-0x0cf7 window]
[    0.440783] pci_bus 0000:03: resource 5 [io  0x0d00-0xffff window]
[    0.440788] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.440794] pci_bus 0000:03: resource 7 [mem 0x000c0000-0x000dffff window]
[    0.440799] pci_bus 0000:03: resource 8 [mem 0x7f750000-0xfebfffff window]
[    0.441049] NET: Registered protocol family 2
[    0.441577] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.441636] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[    0.441873] TCP: Hash tables configured (established 8192 bind 8192)
[    0.441939] UDP hash table entries: 512 (order: 3, 32768 bytes)
[    0.441977] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[    0.442226] NET: Registered protocol family 1
[    0.442289] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.445268] PCI: CLS 64 bytes, default 64
[    0.445493] Unpacking initramfs...
[    1.445081] Freeing initrd memory: 17888K (f5cff000 - f6e77000)
[    1.446804] audit: initializing netlink subsys (disabled)
[    1.446866] audit: type=2000 audit(1509696225.444:1): initialized
[    1.448599] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    1.458299] zbud: loaded
[    1.461328] bounce: pool size: 64 pages
[    1.461527] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.461644] io scheduler noop registered
[    1.461650] io scheduler deadline registered
[    1.461822] io scheduler cfq registered (default)
[    1.463334] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.463365] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.463439] intel_idle: MWAIT substates: 0x10
[    1.463443] intel_idle: v0.4.1 model 0x1C
[    1.463626] intel_idle: lapic_timer_reliable_states 0x2
[    1.463996] GHES: HEST is not enabled!
[    1.464259] isapnp: Scanning for PnP cards...
[    1.817834] isapnp: No Plug & Play device found
[    1.818173] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.838725] 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    1.859477] 00:03: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[    1.860944] Linux agpgart interface v0.103
[    1.862535] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    1.863425] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.863632] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.864224] mousedev: PS/2 mouse device common for all mice
[    1.864400] rtc_cmos 00:01: RTC can wake from S4
[    1.864739] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.864890] rtc_cmos 00:01: alarms up to one month, 242 bytes nvram, hpet irqs
[    1.866975] NET: Registered protocol family 10
[    1.867972] mip6: Mobile IPv6
[    1.867982] NET: Registered protocol family 17
[    1.867993] mpls_gso: MPLS GSO support
[    1.868793] microcode: sig=0x106c2, pf=0x4, revision=0x218
[    1.868987] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.868998] Using IPI No-Shortcut mode
[    1.869626] registered taskstats version 1
[    1.869722] zswap: loaded using pool lzo/zbud
[    1.869850] ima: No TPM chip found, activating TPM-bypass!
[    1.870523] rtc_cmos 00:01: setting system clock to 2017-11-03 08:03:46 UTC (1509696226)
[    1.870708] PM: Hibernation image not present or could not be loaded.
[    1.872217] Freeing unused kernel memory: 1052K (d1827000 - d192e000)
[    1.872541] Write protecting the kernel text: 5972k
[    1.872802] Write protecting the kernel read-only data: 1748k
[    1.872806] NX-protecting the kernel data: 4268k
[    1.873458] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.931843] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.932629] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.937741] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.939446] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.943626] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.944235] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.946336] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.946702] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.947068] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.947378] random: udevadm: uninitialized urandom read (16 bytes read)
[    2.062499] thermal LNXTHERM:00: registered as thermal_zone0
[    2.062510] ACPI: Thermal Zone [THRM] (30 C)
[    2.198164] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    2.198200] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[    2.206808] SCSI subsystem initialized
[    2.207348] ACPI: bus type USB registered
[    2.212273] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    2.214332] r8169 0000:02:00.0 eth0: RTL8102e at 0xf821c000, 00:30:18:a6:5b:cb, XID 14a00000 IRQ 26
[    2.216941] usbcore: registered new interface driver usbfs
[    2.217042] usbcore: registered new interface driver hub
[    2.219223] usbcore: registered new device driver usb
[    2.232861] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.234707] uhci_hcd: USB Universal Host Controller Interface driver
[    2.237364] ehci-pci: EHCI PCI platform driver
[    2.238063] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    2.238097] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[    2.238132] ehci-pci 0000:00:1d.7: debug port 1
[    2.242133] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    2.252969] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfdfff000
[    2.254866] libata version 3.00 loaded.
[    2.268193] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    2.268572] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.268583] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.268590] usb usb1: Product: EHCI Host Controller
[    2.268597] usb usb1: Manufacturer: Linux 4.9.0-3-rt-686-pae ehci_hcd
[    2.268603] usb usb1: SerialNumber: 0000:00:1d.7
[    2.269597] hub 1-0:1.0: USB hub found
[    2.269663] hub 1-0:1.0: 8 ports detected
[    2.271980] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    2.272132] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    2.272159] uhci_hcd 0000:00:1d.0: detected 2 ports
[    2.278540] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fe00
[    2.279702] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    2.279714] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.279721] usb usb2: Product: UHCI Host Controller
[    2.279728] usb usb2: Manufacturer: Linux 4.9.0-3-rt-686-pae uhci_hcd
[    2.279735] usb usb2: SerialNumber: 0000:00:1d.0
[    2.280846] hub 2-0:1.0: USB hub found
[    2.280919] hub 2-0:1.0: 2 ports detected
[    2.282017] ata_piix 0000:00:1f.2: version 2.13
[    2.282458] ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
[    2.308960] scsi host0: ata_piix
[    2.328146] scsi host1: ata_piix
[    2.328607] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf800 irq 14
[    2.328616] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xf808 irq 15
[    2.329186] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    2.329224] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[    2.329248] uhci_hcd 0000:00:1d.1: detected 2 ports
[    2.332391] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fd00
[    2.332832] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.332842] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.332850] usb usb3: Product: UHCI Host Controller
[    2.332856] usb usb3: Manufacturer: Linux 4.9.0-3-rt-686-pae uhci_hcd
[    2.332863] usb usb3: SerialNumber: 0000:00:1d.1
[    2.334607] hub 3-0:1.0: USB hub found
[    2.334683] hub 3-0:1.0: 2 ports detected
[    2.336208] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    2.336242] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[    2.336268] uhci_hcd 0000:00:1d.2: detected 2 ports
[    2.339461] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fc00
[    2.339886] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    2.339896] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.339904] usb usb4: Product: UHCI Host Controller
[    2.339911] usb usb4: Manufacturer: Linux 4.9.0-3-rt-686-pae uhci_hcd
[    2.339917] usb usb4: SerialNumber: 0000:00:1d.2
[    2.340960] hub 4-0:1.0: USB hub found
[    2.341018] hub 4-0:1.0: 2 ports detected
[    2.346006] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[    2.346043] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[    2.346067] uhci_hcd 0000:00:1d.3: detected 2 ports
[    2.351170] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000fb00
[    2.351549] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    2.351559] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.351566] usb usb5: Product: UHCI Host Controller
[    2.351572] usb usb5: Manufacturer: Linux 4.9.0-3-rt-686-pae uhci_hcd
[    2.351579] usb usb5: SerialNumber: 0000:00:1d.3
[    2.352652] hub 5-0:1.0: USB hub found
[    2.352710] hub 5-0:1.0: 2 ports detected
[    2.361089] r8169 0000:02:00.0 enp2s0: renamed from eth0
[    2.464063] tsc: Refined TSC clocksource calibration: 1599.980 MHz
[    2.464081] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x17101205016, max_idle_ns: 440795202977 ns
[    2.490770] ata1.00: supports DRM functions and may not be fully accessible
[    2.490779] ata1.00: ATA-9: Samsung SSD 840 EVO 250GB, EXT0BB6Q, max UDMA/133
[    2.490784] ata1.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 0/32)
[    2.493364] ata1.00: supports DRM functions and may not be fully accessible
[    2.493376] ata1.00: configured for UDMA/133
[    2.493962] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 840  BB6Q PQ: 0 ANSI: 5
[    2.555364] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[    2.555841] sd 0:0:0:0: [sda] Write Protect is off
[    2.555850] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.555993] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.559299]  sda: sda1 sda2 < sda5 >
[    2.561673] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.744087] usb 2-2: new low-speed USB device number 2 using uhci_hcd
[    3.133122] usb 2-2: New USB device found, idVendor=05d5, idProduct=6781
[    3.133129] usb 2-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    3.133133] usb 2-2: Product: USB KB
[    3.142224] hidraw: raw HID events driver (C) Jiri Kosina
[    3.181905] usbcore: registered new interface driver usbhid
[    3.181911] usbhid: USB HID core driver
[    3.187032] input: USB KB as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/0003:05D5:6781.0001/input/input3
[    3.244997] hid-generic 0003:05D5:6781.0001: input,hidraw0: USB HID v1.10 Keyboard [USB KB] on usb-0000:00:1d.0-2/input0
[    3.247398] input: USB KB as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.1/0003:05D5:6781.0002/input/input4
[    3.304613] hid-generic 0003:05D5:6781.0002: input,hidraw1: USB HID v1.10 Mouse [USB KB] on usb-0000:00:1d.0-2/input1
[    3.476065] usb 3-2: new low-speed USB device number 2 using uhci_hcd
[    3.488228] clocksource: Switched to clocksource tsc
[    3.739169] usb 3-2: New USB device found, idVendor=1241, idProduct=1503
[    3.739177] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.739182] usb 3-2: Product: USB Keyboard
[    3.739186] usb 3-2: Manufacturer:
[    3.791660] input:   USB Keyboard as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/0003:1241:1503.0003/input/input5
[    3.848986] hid-generic 0003:1241:1503.0003: input,hidraw2: USB HID v1.10 Keyboard [  USB Keyboard] on usb-0000:00:1d.1-2/input0
[    3.918166] random: fast init done
[    3.935442] input:   USB Keyboard as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.1/0003:1241:1503.0004/input/input6
[    3.992316] hid-generic 0003:1241:1503.0004: input,hidraw3: USB HID v1.10 Device [  USB Keyboard] on usb-0000:00:1d.1-2/input1
[    5.344121] floppy0: no floppy controllers found
[    5.553548] PM: Starting manual resume from disk
[    5.553559] PM: Hibernation image partition 8:5 present
[    5.553564] PM: Looking for hibernation image.
[    5.553998] PM: Image not found (code -22)
[    5.554003] PM: Hibernation image not present or could not be loaded.
[    5.916919] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    6.336153] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.365103] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    6.365668] systemd[1]: Detected architecture x86.
[    6.366696] systemd[1]: Set hostname to <CNC3000>.
[    6.670596] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[    6.670685] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[    6.673733] systemd[1]: Listening on Journal Socket.
[    6.674763] systemd[1]: Created slice System Slice.
[    6.675495] systemd[1]: Created slice system-getty.slice.
[    6.675800] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    6.675976] systemd[1]: Listening on Syslog Socket.
[    6.807383] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[    8.204936] systemd-journald[217]: Received request to flush runtime journal from PID 1
[    8.370769] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input7
[    8.370788] ACPI: Power Button [PWRB]
[    8.400653] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input8
[    8.400672] ACPI: Power Button [PWRF]
[    9.080185] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    9.247570] [drm] Initialized
[    9.383951] intel_rng: FWH not detected
[    9.574268] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000429-0x0000000000000429 (\PM2S) (20160831/utaddress-247)
[    9.574296] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.574305] ACPI Warning: SystemIO range 0x00000000000004B0-0x00000000000004BF conflicts with OpRegion 0x00000000000004B8-0x00000000000004BB (\GPO2) (20160831/utaddress-247)
[    9.574323] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.574330] ACPI Warning: SystemIO range 0x0000000000000480-0x00000000000004AF conflicts with OpRegion 0x000000000000048C-0x000000000000048F (\GPO) (20160831/utaddress-247)
[    9.574348] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.574353] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    9.608165] pci 0000:00:00.0: Intel 945G Chipset
[    9.608211] pci 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[    9.608316] pci 0000:00:00.0: detected 8192K stolen memory
[    9.608435] [drm] Memory usable by graphics device = 256M
[    9.608445] [drm] Replacing VGA console driver
[    9.618034] Console: switching to colour dummy device 80x25
[    9.620485] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    9.620491] [drm] Driver supports precise vblank timestamp query.
[    9.656392] leds_ss4200: no LED devices found
[    9.717775] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    9.755221] [drm] RC6 disabled, disabling runtime PM support
[    9.755331] [drm] initialized overlay support
[    9.799537] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[    9.901787] fbcon: inteldrmfb (fb0) is primary device
[    9.990553] Console: switching to colour frame buffer device 128x48
[   10.059232] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[   10.062278] input: PC Speaker as /devices/platform/pcspkr/input/input9
[   10.065492] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   10.625249] intel_powerclamp: No package C-state available
[   10.690581] intel_powerclamp: No package C-state available
[   11.109713] Adding 2085884k swap on /dev/sda5.  Priority:-1 extents:1 across:2085884k SSFS
[   11.426152] ppdev: user-space parallel port driver
[   11.544839] iTCO_vendor_support: vendor-support=0
[   11.568939] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   11.571893] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0460)
[   11.604921] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   12.256162] floppy0: no floppy controllers found
[   13.759213] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[   13.773439] r8169 0000:02:00.0 enp2s0: link down
[   13.773460] r8169 0000:02:00.0 enp2s0: link down
[   13.773679] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[   15.327847] r8169 0000:02:00.0 enp2s0: link up
[   15.327880] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[   29.610321] random: crng init done
[   30.908304] usb 3-2: USB disconnect, device number 2
[  206.393753] perf: interrupt took too long (2519 > 2500), lowering kernel.perf_event_max_sample_rate to 79250
[  253.830966] perf: interrupt took too long (3196 > 3148), lowering kernel.perf_event_max_sample_rate to 62500
[  295.475843] perf: interrupt took too long (4041 > 3995), lowering kernel.perf_event_max_sample_rate to 49250
[  324.892777] perf: interrupt took too long (5075 > 5051), lowering kernel.perf_event_max_sample_rate to 39250
[  462.571962] perf: interrupt took too long (6345 > 6343), lowering kernel.perf_event_max_sample_rate to 31500
[ 3009.976067] usb 1-4: new high-speed USB device number 4 using ehci-pci
[ 3010.283824] usb 1-4: New USB device found, idVendor=148f, idProduct=2570
[ 3010.283833] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3010.283838] usb 1-4: Product: 802.11g WLAN
[ 3010.283842] usb 1-4: Manufacturer: Ralink
[ 3010.624089] usb 1-4: reset high-speed USB device number 4 using ehci-pci
[ 3010.953704] ieee80211 phy0: rt2x00_set_chip: Info - Chipset detected - rt: 2570, rf: 0005, rev: 0005
[ 3010.979592] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 3010.983680] usbcore: registered new interface driver rt2500usb
[ 3011.130159] rt2500usb 1-4:1.0 wlx0006f40c7d59: renamed from wlan0
[ 3011.207253] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3011.395942] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3011.722698] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3011.829945] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3065.475318] r8169 0000:02:00.0 enp2s0: link down
[ 3102.006886] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3103.334437] wlx0006f40c7d59: authenticate with f4:06:8d:b8:9c:75
[ 3103.382183] wlx0006f40c7d59: send auth to f4:06:8d:b8:9c:75 (try 1/3)
[ 3103.386411] wlx0006f40c7d59: authenticated
[ 3108.387450] wlx0006f40c7d59: aborting authentication with f4:06:8d:b8:9c:75 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3109.695292] wlx0006f40c7d59: authenticate with f4:06:8d:b8:9c:75
[ 3109.745943] wlx0006f40c7d59: send auth to f4:06:8d:b8:9c:75 (try 1/3)
[ 3109.751240] wlx0006f40c7d59: authenticated
[ 3114.749096] wlx0006f40c7d59: aborting authentication with f4:06:8d:b8:9c:75 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3116.460753] wlx0006f40c7d59: authenticate with f4:06:8d:b8:9c:75
[ 3116.503958] wlx0006f40c7d59: send auth to f4:06:8d:b8:9c:75 (try 1/3)
[ 3116.508239] wlx0006f40c7d59: authenticated
[ 3121.509890] wlx0006f40c7d59: aborting authentication with f4:06:8d:b8:9c:75 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3123.722522] wlx0006f40c7d59: authenticate with f4:06:8d:b8:9c:75
[ 3123.775881] wlx0006f40c7d59: send auth to f4:06:8d:b8:9c:75 (try 1/3)
[ 3123.780162] wlx0006f40c7d59: authenticated
[ 3127.001798] wlx0006f40c7d59: aborting authentication with f4:06:8d:b8:9c:75 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3127.054316] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3127.374883] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3135.738818] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3157.766771] wlx0006f40c7d59: authenticate with ec:08:6b:25:bf:78
[ 3157.813949] wlx0006f40c7d59: send auth to ec:08:6b:25:bf:78 (try 1/3)
[ 3157.815666] wlx0006f40c7d59: authenticated
[ 3162.815159] wlx0006f40c7d59: aborting authentication with ec:08:6b:25:bf:78 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3174.066759] wlx0006f40c7d59: authenticate with ec:08:6b:25:bf:78
[ 3174.121917] wlx0006f40c7d59: send auth to ec:08:6b:25:bf:78 (try 1/3)
[ 3174.123621] wlx0006f40c7d59: authenticated
[ 3179.127190] wlx0006f40c7d59: aborting authentication with ec:08:6b:25:bf:78 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3182.053141] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3182.370785] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 3193.036703] r8169 0000:02:00.0 enp2s0: link up
[ 3208.022852] usb 1-4: USB disconnect, device number 4
[ 3253.210692] perf: interrupt took too long (7950 > 7931), lowering kernel.perf_event_max_sample_rate to 25000
bengt@CNC3000:~$
This is after I plugged in the USB2LAN adapter
Time to create page: 0.111 seconds
