Reliable USB WiFi?
03 Nov 2017 04:09 #101224 by tecno
Replied by tecno on topic Reliable USB WiFi?
I will reboot and start all over to get a clean dmesg
03 Nov 2017 04:12 #101225 by tecno
This is after reboot
bengt@CNC3000:~$ sudo dmesg
[sudo] lösenord för bengt:
[    0.000000] Linux version 4.9.0-3-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #1 SMP PREEMPT RT Debian 4.9.30-2+deb9u2 (2017-06-26)
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] x86/fpu: Using 'eager' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f3ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f400-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007f68ffff] usable
[    0.000000] BIOS-e820: [mem 0x000000007f690000-0x000000007f6dffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007f6e0000-0x000000007f6e2fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000007f6e3000-0x000000007f6effff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000007f6f0000-0x000000007f6fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000ffffffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.2 present.
[    0.000000] DMI:    /LakePort, BIOS 6.00 PG 11/19/2008
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x7f690 max_arch_pfn = 0x1000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-C9FFF write-protect
[    0.000000]   CA000-F7FFF uncachable
[    0.000000]   F8000-FBFFF write-through
[    0.000000]   FC000-FFFFF uncachable
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask 080000000 write-back
[    0.000000]   1 base 07F800000 mask 0FF800000 uncachable
[    0.000000]   2 base 07F700000 mask 0FFF00000 uncachable
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] found SMP MP-table at [mem 0x000f3d40-0x000f3d4f] mapped at [c00f3d40]
[    0.000000] initial memory mapped: [mem 0x00000000-0x15dfffff]
[    0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[    0.000000] BRK [0x15a78000, 0x15a78fff] PGTABLE
[    0.000000] BRK [0x15a79000, 0x15a7afff] PGTABLE
[    0.000000] BRK [0x15a7b000, 0x15a7bfff] PGTABLE
[    0.000000] BRK [0x15a7c000, 0x15a7cfff] PGTABLE
[    0.000000] RAMDISK: [mem 0x35cff000-0x36e76fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F7FE0 000014 (v00 IntelR)
[    0.000000] ACPI: RSDT 0x000000007F6E3000 000030 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: FACP 0x000000007F6E3080 000074 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: DSDT 0x000000007F6E3100 004426 (v01 INTELR AWRDACPI 00001000 MSFT 03000000)
[    0.000000] ACPI: FACS 0x000000007F6E0000 000040
[    0.000000] ACPI: MCFG 0x000000007F6E7600 00003C (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: APIC 0x000000007F6E7540 000084 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 1148MB HIGHMEM available.
[    0.000000] 889MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 379fe000
[    0.000000]   low ram: 0 - 379fe000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   Normal   [mem 0x0000000001000000-0x00000000379fdfff]
[    0.000000]   HighMem  [mem 0x00000000379fe000-0x000000007f68ffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000007f68ffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000007f68ffff]
[    0.000000] On node 0 totalpages: 521774
[    0.000000] free_area_init_node: node 0, pgdat d5814000, node_mem_map f4913028
[    0.000000]   DMA zone: 40 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   Normal zone: 2185 pages used for memmap
[    0.000000]   Normal zone: 223742 pages, LIFO batch:31
[    0.000000]   HighMem zone: 294034 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] Reserving Intel graphics memory at 0x000000007f800000-0x000000007fffffff
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000effff]
[    0.000000] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
[    0.000000] e820: [mem 0x80000000-0xdfffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] percpu: Embedded 101 pages/cpu @f7867000 s381216 r0 d32480 u413696
[    0.000000] pcpu-alloc: s381216 r0 d32480 u413696 alloc=101*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 519549
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-3-rt-686-pae root=UUID=ef18c43d-9e90-4481-826c-a53ae788db66 ro quiet
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] microcode: microcode updated early to revision 0x218, date = 2009-04-10
[    0.000000] Initializing CPU#0
[    0.000000] Initializing HighMem for node 0 (000379fe:0007f690)
[    0.000000] Initializing Movable for node 0 (00000000:00000000)
[    0.000000] Memory: 2035068K/2087096K available (5968K kernel code, 622K rwdata, 1744K rodata, 1052K init, 592K bss, 52028K reserved, 0K cma-reserved, 1176136K highmem)
[    0.000000] virtual kernel memory layout:
                   fixmap  : 0xffd36000 - 0xfffff000   (2852 kB)
                   pkmap   : 0xffa00000 - 0xffc00000   (2048 kB)
                   vmalloc : 0xf81fe000 - 0xff9fe000   ( 120 MB)
                   lowmem  : 0xc0000000 - 0xf79fe000   ( 889 MB)
                     .init : 0xd5827000 - 0xd592e000   (1052 kB)
                     .data : 0xd55d44fa - 0xd5825840   (2372 kB)
                     .text : 0xd5000000 - 0xd55d44fa   (5969 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=4.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS:2304 nr_irqs:456 16
[    0.000000] CPU 0 irqstacks, hard=f703e000 soft=f7080000
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 1599.892 MHz processor
[    0.008010] Calibrating delay loop (skipped), value calculated using timer frequency.. 3199.78 BogoMIPS (lpj=6399568)
[    0.008013] pid_max: default: 32768 minimum: 301
[    0.008075] ACPI: Core revision 20160831
[    0.017755] ACPI: 1 ACPI AML tables successfully acquired and loaded
[    0.017838] Security Framework initialized
[    0.017841] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.017853] AppArmor: AppArmor disabled by boot time parameter
[    0.017890] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.017895] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.018613] CPU: Physical Processor ID: 0
[    0.018615] CPU: Processor Core ID: 0
[    0.018623] mce: CPU supports 5 MCE banks
[    0.018636] CPU0: Thermal monitoring enabled (TM1)
[    0.018646] process: using mwait in idle threads
[    0.018661] Last level iTLB entries: 4KB 32, 2MB 0, 4MB 0
[    0.018663] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 8, 1GB 0
[    0.019024] Freeing SMP alternatives memory: 24K (d592e000 - d5934000)
[    0.024015] ftrace: allocating 23979 entries in 47 pages
[    0.040252] smpboot: Max logical packages: 4
[    0.040266] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.040707] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.084000] smpboot: CPU0: Intel(R) Atom(TM) CPU  230   @ 1.60GHz (family: 0x6, model: 0x1c, stepping: 0x2)
[    0.084000] Performance Events: PEBS fmt0+, LBR disabled due to erratumAtom events, Intel PMU driver.
[    0.084000] ... version:                3
[    0.084000] ... bit width:              40
[    0.084000] ... generic registers:      2
[    0.084000] ... value mask:             000000ffffffffff
[    0.084000] ... max period:             000000007fffffff
[    0.084000] ... fixed-purpose events:   3
[    0.084000] ... event mask:             0000000700000003
[    0.136361] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.188078] CPU 1 irqstacks, hard=f71cc000 soft=f71ce000
[    0.188084] x86: Booting SMP configuration:
[    0.188088] .... node  #0, CPUs:      #1
[    0.012000] Initializing CPU#1
[    0.270073] x86: Booted up 1 node, 2 CPUs
[    0.270073] smpboot: Total of 2 processors activated (6399.87 BogoMIPS)
[    0.270073] devtmpfs: initialized
[    0.272066] PM: Registering ACPI NVS region [mem 0x7f6e0000-0x7f6e2fff] (12288 bytes)
[    0.272066] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.272066] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.272066] pinctrl core: initialized pinctrl subsystem
[    0.272066] NET: Registered protocol family 16
[    0.276053] cpuidle: using governor ladder
[    0.280038] cpuidle: using governor menu
[    0.280134] ACPI: bus type PCI registered
[    0.280141] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.280372] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.280376] PCI: Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub with MMCONFIG support
[    0.280385] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.280387] PCI: Using MMCONFIG for extended config space
[    0.280390] PCI: Using configuration type 1 for base access
[    0.284280] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.284754] ACPI: Added _OSI(Module Device)
[    0.284759] ACPI: Added _OSI(Processor Device)
[    0.284763] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.284767] ACPI: Added _OSI(Processor Aggregator Device)
[    0.296691] ACPI: Interpreter enabled
[    0.296750] ACPI: (supports S0 S1 S4 S5)
[    0.296756] ACPI: Using IOAPIC for interrupt routing
[    0.296847] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.315533] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.315551] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.315567] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[    0.316480] PCI host bridge to bus 0000:00
[    0.316491] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.316497] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.316502] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.316508] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.316513] pci_bus 0000:00: root bus resource [mem 0x7f750000-0xfebfffff window]
[    0.316521] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.316545] pci 0000:00:00.0: [8086:2770] type 00 class 0x060000
[    0.316924] pci 0000:00:02.0: [8086:2772] type 00 class 0x030000
[    0.316946] pci 0000:00:02.0: reg 0x10: [mem 0xfdf00000-0xfdf7ffff]
[    0.316958] pci 0000:00:02.0: reg 0x14: [io  0xff00-0xff07]
[    0.316970] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff pref]
[    0.316981] pci 0000:00:02.0: reg 0x1c: [mem 0xfdf80000-0xfdfbffff]
[    0.317373] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[    0.317494] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.317689] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.317885] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[    0.318001] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.318219] pci 0000:00:1c.1: System wakeup disabled by ACPI
[    0.318422] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[    0.318481] pci 0000:00:1d.0: reg 0x20: [io  0xfe00-0xfe1f]
[    0.318704] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.318893] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[    0.318950] pci 0000:00:1d.1: reg 0x20: [io  0xfd00-0xfd1f]
[    0.319165] pci 0000:00:1d.1: System wakeup disabled by ACPI
[    0.319354] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[    0.319412] pci 0000:00:1d.2: reg 0x20: [io  0xfc00-0xfc1f]
[    0.319629] pci 0000:00:1d.2: System wakeup disabled by ACPI
[    0.319818] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[    0.319876] pci 0000:00:1d.3: reg 0x20: [io  0xfb00-0xfb1f]
[    0.320142] pci 0000:00:1d.3: System wakeup disabled by ACPI
[    0.320342] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[    0.320371] pci 0000:00:1d.7: reg 0x10: [mem 0xfdfff000-0xfdfff3ff]
[    0.320487] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.320676] pci 0000:00:1d.7: System wakeup disabled by ACPI
[    0.320860] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.321120] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.321307] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[    0.321434] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[    0.321451] pci 0000:00:1f.0: quirk: [io  0x0400-0x047f] claimed by ICH6 ACPI/GPIO/TCO
[    0.321461] pci 0000:00:1f.0: quirk: [io  0x0480-0x04bf] claimed by ICH6 GPIO
[    0.321470] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0294 (mask 0003)
[    0.321849] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x010180
[    0.321873] pci 0000:00:1f.2: reg 0x10: [io  0x0000-0x0007]
[    0.321887] pci 0000:00:1f.2: reg 0x14: [io  0x0000-0x0003]
[    0.321900] pci 0000:00:1f.2: reg 0x18: [io  0x0000-0x0007]
[    0.321913] pci 0000:00:1f.2: reg 0x1c: [io  0x0000-0x0003]
[    0.321927] pci 0000:00:1f.2: reg 0x20: [io  0xf800-0xf80f]
[    0.321952] pci 0000:00:1f.2: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
[    0.321956] pci 0000:00:1f.2: legacy IDE quirk: reg 0x14: [io  0x03f6]
[    0.321961] pci 0000:00:1f.2: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
[    0.321965] pci 0000:00:1f.2: legacy IDE quirk: reg 0x1c: [io  0x0376]
[    0.322008] pci 0000:00:1f.2: PME# supported from D3hot
[    0.322393] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[    0.322463] pci 0000:00:1f.3: reg 0x20: [io  0x0500-0x051f]
[    0.322962] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.322971] pci 0000:00:1c.0:   bridge window [io  0xc000-0xcfff]
[    0.322979] pci 0000:00:1c.0:   bridge window [mem 0xfdd00000-0xfddfffff]
[    0.322989] pci 0000:00:1c.0:   bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[    0.323160] pci 0000:02:00.0: [10ec:8136] type 00 class 0x020000
[    0.323191] pci 0000:02:00.0: reg 0x10: [io  0xbe00-0xbeff]
[    0.323230] pci 0000:02:00.0: reg 0x18: [mem 0xfdeff000-0xfdefffff 64bit pref]
[    0.323255] pci 0000:02:00.0: reg 0x20: [mem 0xfdee0000-0xfdeeffff 64bit pref]
[    0.323274] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[    0.323391] pci 0000:02:00.0: supports D1 D2
[    0.323397] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.332029] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.332039] pci 0000:00:1c.1:   bridge window [io  0xb000-0xbfff]
[    0.332047] pci 0000:00:1c.1:   bridge window [mem 0xfd900000-0xfd9fffff]
[    0.332057] pci 0000:00:1c.1:   bridge window [mem 0xfde00000-0xfdefffff 64bit pref]
[    0.332240] pci 0000:00:1e.0: PCI bridge to [bus 03] (subtractive decode)
[    0.332249] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
[    0.332257] pci 0000:00:1e.0:   bridge window [mem 0xfdc00000-0xfdcfffff]
[    0.332267] pci 0000:00:1e.0:   bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.332273] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.332278] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.332283] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.332288] pci 0000:00:1e.0:   bridge window [mem 0x000c0000-0x000dffff window] (subtractive decode)
[    0.332294] pci 0000:00:1e.0:   bridge window [mem 0x7f750000-0xfebfffff window] (subtractive decode)
[    0.332321] pci_bus 0000:00: on NUMA node 0
[    0.332765] ACPI: PCI Interrupt Link [LNKA] (IRQs *5 7 9 10 11 12 14 15)
[    0.332985] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 7 9 *10 11 12 14 15)
[    0.333199] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 7 9 *10 11 12 14 15)
[    0.333413] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 7 9 10 *11 12 14 15)
[    0.333627] ACPI: PCI Interrupt Link [LNKE] (IRQs 5 7 *9 10 11 12 14 15)
[    0.333839] ACPI: PCI Interrupt Link [LNKF] (IRQs 5 7 9 10 11 12 14 15) *0, disabled.
[    0.334087] ACPI: PCI Interrupt Link [LNK0] (IRQs 5 7 9 10 11 12 14 15) *0, disabled.
[    0.334307] ACPI: PCI Interrupt Link [LNK1] (IRQs 5 7 9 10 *11 12 14 15)
[    0.334704] ACPI: Enabled 2 GPEs in block 00 to 1F
[    0.336063] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.336063] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.336063] vgaarb: loaded
[    0.336063] vgaarb: bridge control possible 0000:00:02.0
[    0.336306] PCI: Using ACPI for IRQ routing
[    0.345357] PCI: pci_cache_line_size set to 64 bytes
[    0.345438] e820: reserve RAM buffer [mem 0x0009f400-0x0009ffff]
[    0.345446] e820: reserve RAM buffer [mem 0x7f690000-0x7fffffff]
[    0.346401] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.346416] hpet clockevent registered
[    0.346426] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[    0.346433] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.346445] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[    0.348090] clocksource: Switched to clocksource hpet
[    0.393897] VFS: Disk quotas dquot_6.6.0
[    0.393961] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.394329] pnp: PnP ACPI init
[    0.394905] system 00:00: [io  0x04d0-0x04d1] has been reserved
[    0.394916] system 00:00: [io  0x0290-0x029f] has been reserved
[    0.394923] system 00:00: [io  0x0800-0x0805] has been reserved
[    0.394930] system 00:00: [io  0x0290-0x0297] has been reserved
[    0.394936] system 00:00: [io  0x0880-0x088f] has been reserved
[    0.394951] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.395126] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.396094] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.396833] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.397728] system 00:04: [io  0x0400-0x04bf] could not be reserved
[    0.397742] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.398512] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[    0.398525] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.398920] system 00:06: [mem 0x000f0000-0x000fffff] could not be reserved
[    0.398929] system 00:06: [mem 0x7f6e0000-0x7f6fffff] could not be reserved
[    0.398936] system 00:06: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.398943] system 00:06: [mem 0x00100000-0x7f6dffff] could not be reserved
[    0.398950] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.398956] system 00:06: [mem 0xfed13000-0xfed1dfff] has been reserved
[    0.398963] system 00:06: [mem 0xfed20000-0xfed8ffff] has been reserved
[    0.398970] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.398976] system 00:06: [mem 0xffb00000-0xffb7ffff] has been reserved
[    0.398983] system 00:06: [mem 0xfff00000-0xffffffff] has been reserved
[    0.398990] system 00:06: [mem 0x000e0000-0x000effff] has been reserved
[    0.399001] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.399027] pnp: PnP ACPI: found 7 devices
[    0.399034] PnPBIOS: Disabled
[    0.444323] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.444394] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.444402] pci 0000:00:1c.0:   bridge window [io  0xc000-0xcfff]
[    0.444411] pci 0000:00:1c.0:   bridge window [mem 0xfdd00000-0xfddfffff]
[    0.444419] pci 0000:00:1c.0:   bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[    0.444440] pci 0000:02:00.0: BAR 6: assigned [mem 0xfd900000-0xfd91ffff pref]
[    0.444447] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.444453] pci 0000:00:1c.1:   bridge window [io  0xb000-0xbfff]
[    0.444462] pci 0000:00:1c.1:   bridge window [mem 0xfd900000-0xfd9fffff]
[    0.444470] pci 0000:00:1c.1:   bridge window [mem 0xfde00000-0xfdefffff 64bit pref]
[    0.444481] pci 0000:00:1e.0: PCI bridge to [bus 03]
[    0.444487] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
[    0.444495] pci 0000:00:1e.0:   bridge window [mem 0xfdc00000-0xfdcfffff]
[    0.444503] pci 0000:00:1e.0:   bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.444515] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.444521] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.444527] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.444532] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff window]
[    0.444537] pci_bus 0000:00: resource 8 [mem 0x7f750000-0xfebfffff window]
[    0.444543] pci_bus 0000:01: resource 0 [io  0xc000-0xcfff]
[    0.444548] pci_bus 0000:01: resource 1 [mem 0xfdd00000-0xfddfffff]
[    0.444553] pci_bus 0000:01: resource 2 [mem 0xfda00000-0xfdafffff 64bit pref]
[    0.444559] pci_bus 0000:02: resource 0 [io  0xb000-0xbfff]
[    0.444564] pci_bus 0000:02: resource 1 [mem 0xfd900000-0xfd9fffff]
[    0.444569] pci_bus 0000:02: resource 2 [mem 0xfde00000-0xfdefffff 64bit pref]
[    0.444575] pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
[    0.444580] pci_bus 0000:03: resource 1 [mem 0xfdc00000-0xfdcfffff]
[    0.444585] pci_bus 0000:03: resource 2 [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.444590] pci_bus 0000:03: resource 4 [io  0x0000-0x0cf7 window]
[    0.444595] pci_bus 0000:03: resource 5 [io  0x0d00-0xffff window]
[    0.444600] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.444606] pci_bus 0000:03: resource 7 [mem 0x000c0000-0x000dffff window]
[    0.444611] pci_bus 0000:03: resource 8 [mem 0x7f750000-0xfebfffff window]
[    0.444873] NET: Registered protocol family 2
[    0.445415] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.445475] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[    0.445717] TCP: Hash tables configured (established 8192 bind 8192)
[    0.445786] UDP hash table entries: 512 (order: 3, 32768 bytes)
[    0.445827] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[    0.446092] NET: Registered protocol family 1
[    0.446148] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.449127] PCI: CLS 64 bytes, default 64
[    0.449351] Unpacking initramfs...
[    1.449502] Freeing initrd memory: 17888K (f5cff000 - f6e77000)
[    1.451221] audit: initializing netlink subsys (disabled)
[    1.451277] audit: type=2000 audit(1509700234.448:1): initialized
[    1.452979] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    1.462695] zbud: loaded
[    1.465615] bounce: pool size: 64 pages
[    1.465823] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.465953] io scheduler noop registered
[    1.465959] io scheduler deadline registered
[    1.466131] io scheduler cfq registered (default)
[    1.467629] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.467662] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.467743] intel_idle: MWAIT substates: 0x10
[    1.467747] intel_idle: v0.4.1 model 0x1C
[    1.467929] intel_idle: lapic_timer_reliable_states 0x2
[    1.468420] GHES: HEST is not enabled!
[    1.468589] isapnp: Scanning for PnP cards...
[    1.822079] isapnp: No Plug & Play device found
[    1.822414] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.842959] 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    1.863687] 00:03: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[    1.865133] Linux agpgart interface v0.103
[    1.866736] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    1.867612] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.867817] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.868442] mousedev: PS/2 mouse device common for all mice
[    1.868617] rtc_cmos 00:01: RTC can wake from S4
[    1.868960] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.869120] rtc_cmos 00:01: alarms up to one month, 242 bytes nvram, hpet irqs
[    1.871209] NET: Registered protocol family 10
[    1.872293] mip6: Mobile IPv6
[    1.872303] NET: Registered protocol family 17
[    1.872317] mpls_gso: MPLS GSO support
[    1.873060] microcode: sig=0x106c2, pf=0x4, revision=0x218
[    1.873262] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.873273] Using IPI No-Shortcut mode
[    1.873904] registered taskstats version 1
[    1.873981] zswap: loaded using pool lzo/zbud
[    1.874122] ima: No TPM chip found, activating TPM-bypass!
[    1.874790] rtc_cmos 00:01: setting system clock to 2017-11-03 09:10:35 UTC (1509700235)
[    1.874978] PM: Hibernation image not present or could not be loaded.
[    1.876494] Freeing unused kernel memory: 1052K (d5827000 - d592e000)
[    1.876833] Write protecting the kernel text: 5972k
[    1.877096] Write protecting the kernel read-only data: 1748k
[    1.877100] NX-protecting the kernel data: 4268k
[    1.877753] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.935748] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.936600] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.941712] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.943429] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.947609] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.948167] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.950294] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.950655] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.951028] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.951339] random: udevadm: uninitialized urandom read (16 bytes read)
[    2.193209] thermal LNXTHERM:00: registered as thermal_zone0
[    2.193217] ACPI: Thermal Zone [THRM] (30 C)
[    2.207540] ACPI: bus type USB registered
[    2.207724] usbcore: registered new interface driver usbfs
[    2.207819] usbcore: registered new interface driver hub
[    2.209203] usbcore: registered new device driver usb
[    2.219003] SCSI subsystem initialized
[    2.235799] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.246117] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    2.246153] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[    2.246485] ehci-pci: EHCI PCI platform driver
[    2.247647] r8169 0000:02:00.0 eth0: RTL8102e at 0xf8213000, 00:30:18:a6:5b:cb, XID 14a00000 IRQ 26
[    2.250161] uhci_hcd: USB Universal Host Controller Interface driver
[    2.251105] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    2.260823] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    2.260856] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[    2.260890] ehci-pci 0000:00:1d.7: debug port 1
[    2.264887] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    2.267404] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfdfff000
[    2.274074] libata version 3.00 loaded.
[    2.280156] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    2.280534] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.280544] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.280551] usb usb1: Product: EHCI Host Controller
[    2.280558] usb usb1: Manufacturer: Linux 4.9.0-3-rt-686-pae ehci_hcd
[    2.280564] usb usb1: SerialNumber: 0000:00:1d.7
[    2.281553] hub 1-0:1.0: USB hub found
[    2.281617] hub 1-0:1.0: 8 ports detected
[    2.289165] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    2.289202] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    2.289228] uhci_hcd 0000:00:1d.0: detected 2 ports
[    2.293649] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fe00
[    2.294095] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    2.294105] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.294113] usb usb2: Product: UHCI Host Controller
[    2.294120] usb usb2: Manufacturer: Linux 4.9.0-3-rt-686-pae uhci_hcd
[    2.294126] usb usb2: SerialNumber: 0000:00:1d.0
[    2.295139] hub 2-0:1.0: USB hub found
[    2.295208] hub 2-0:1.0: 2 ports detected
[    2.296656] ata_piix 0000:00:1f.2: version 2.13
[    2.297106] ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
[    2.351216] scsi host0: ata_piix
[    2.380547] scsi host1: ata_piix
[    2.381958] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf800 irq 14
[    2.381967] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xf808 irq 15
[    2.382711] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    2.382749] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[    2.382777] uhci_hcd 0000:00:1d.1: detected 2 ports
[    2.385927] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fd00
[    2.386363] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.386374] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.386384] usb usb3: Product: UHCI Host Controller
[    2.386391] usb usb3: Manufacturer: Linux 4.9.0-3-rt-686-pae uhci_hcd
[    2.386397] usb usb3: SerialNumber: 0000:00:1d.1
[    2.395014] hub 3-0:1.0: USB hub found
[    2.395090] hub 3-0:1.0: 2 ports detected
[    2.401465] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    2.401575] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[    2.401599] uhci_hcd 0000:00:1d.2: detected 2 ports
[    2.401847] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fc00
[    2.402267] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    2.402278] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.402286] usb usb4: Product: UHCI Host Controller
[    2.402293] usb usb4: Manufacturer: Linux 4.9.0-3-rt-686-pae uhci_hcd
[    2.402300] usb usb4: SerialNumber: 0000:00:1d.2
[    2.403878] hub 4-0:1.0: USB hub found
[    2.403933] hub 4-0:1.0: 2 ports detected
[    2.405412] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[    2.405451] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[    2.405479] uhci_hcd 0000:00:1d.3: detected 2 ports
[    2.407036] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000fb00
[    2.407413] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    2.407423] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.407430] usb usb5: Product: UHCI Host Controller
[    2.407437] usb usb5: Manufacturer: Linux 4.9.0-3-rt-686-pae uhci_hcd
[    2.407444] usb usb5: SerialNumber: 0000:00:1d.3
[    2.408149] r8169 0000:02:00.0 enp2s0: renamed from eth0
[    2.409762] hub 5-0:1.0: USB hub found
[    2.409821] hub 5-0:1.0: 2 ports detected
[    2.460093] tsc: Refined TSC clocksource calibration: 1599.980 MHz
[    2.460113] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x17101205016, max_idle_ns: 440795202977 ns
[    2.542585] ata1.00: supports DRM functions and may not be fully accessible
[    2.542594] ata1.00: ATA-9: Samsung SSD 840 EVO 250GB, EXT0BB6Q, max UDMA/133
[    2.542599] ata1.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 0/32)
[    2.545175] ata1.00: supports DRM functions and may not be fully accessible
[    2.545186] ata1.00: configured for UDMA/133
[    2.545783] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 840  BB6Q PQ: 0 ANSI: 5
[    2.605798] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[    2.606249] sd 0:0:0:0: [sda] Write Protect is off
[    2.606258] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.606407] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.610244]  sda: sda1 sda2 < sda5 >
[    2.612551] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.756132] usb 2-2: new low-speed USB device number 2 using uhci_hcd
[    3.145128] usb 2-2: New USB device found, idVendor=05d5, idProduct=6781
[    3.145135] usb 2-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    3.145140] usb 2-2: Product: USB KB
[    3.154219] hidraw: raw HID events driver (C) Jiri Kosina
[    3.196985] usbcore: registered new interface driver usbhid
[    3.196993] usbhid: USB HID core driver
[    3.201957] input: USB KB as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/0003:05D5:6781.0001/input/input3
[    3.260995] hid-generic 0003:05D5:6781.0001: input,hidraw0: USB HID v1.10 Keyboard [USB KB] on usb-0000:00:1d.0-2/input0
[    3.263354] input: USB KB as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.1/0003:05D5:6781.0002/input/input4
[    3.320563] hid-generic 0003:05D5:6781.0002: input,hidraw1: USB HID v1.10 Mouse [USB KB] on usb-0000:00:1d.0-2/input1
[    3.484225] clocksource: Switched to clocksource tsc
[    5.340150] floppy0: no floppy controllers found
[    5.546695] PM: Starting manual resume from disk
[    5.546705] PM: Hibernation image partition 8:5 present
[    5.546708] PM: Looking for hibernation image.
[    5.547139] PM: Image not found (code -22)
[    5.547144] PM: Hibernation image not present or could not be loaded.
[    5.875847] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    5.923494] random: fast init done
[    6.338530] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.367277] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    6.367832] systemd[1]: Detected architecture x86.
[    6.368965] systemd[1]: Set hostname to <CNC3000>.
[    6.682241] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[    6.682371] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[    6.685520] systemd[1]: Listening on Journal Socket.
[    6.685972] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    6.686209] systemd[1]: Listening on udev Control Socket.
[    6.687008] systemd[1]: Created slice System Slice.
[    6.697496] systemd[1]: Starting Set the console keyboard layout...
[    6.880435] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[    8.212265] systemd-journald[215]: Received request to flush runtime journal from PID 1
[    8.374595] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[    8.374612] ACPI: Power Button [PWRB]
[    8.427899] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[    8.427917] ACPI: Power Button [PWRF]
[    8.489644] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    8.520253] [drm] Initialized
[    8.794349] pci 0000:00:00.0: Intel 945G Chipset
[    8.794399] pci 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[    8.794500] pci 0000:00:00.0: detected 8192K stolen memory
[    8.794614] [drm] Memory usable by graphics device = 256M
[    8.794624] [drm] Replacing VGA console driver
[    8.811601] Console: switching to colour dummy device 80x25
[    8.811709] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    8.811714] [drm] Driver supports precise vblank timestamp query.
[    8.944434] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    8.984239] [drm] RC6 disabled, disabling runtime PM support
[    8.984345] [drm] initialized overlay support
[    9.034766] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[    9.190608] fbcon: inteldrmfb (fb0) is primary device
[    9.258293] Console: switching to colour frame buffer device 128x48
[    9.304127] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    9.333718] intel_rng: FWH not detected
[    9.481647] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000429-0x0000000000000429 (\PM2S) (20160831/utaddress-247)
[    9.481675] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.481684] ACPI Warning: SystemIO range 0x00000000000004B0-0x00000000000004BF conflicts with OpRegion 0x00000000000004B8-0x00000000000004BB (\GPO2) (20160831/utaddress-247)
[    9.481703] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.481709] ACPI Warning: SystemIO range 0x0000000000000480-0x00000000000004AF conflicts with OpRegion 0x000000000000048C-0x000000000000048F (\GPO) (20160831/utaddress-247)
[    9.481728] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.481733] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    9.545636] leds_ss4200: no LED devices found
[    9.909065] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    9.939280] input: PC Speaker as /devices/platform/pcspkr/input/input7
[   10.297218] intel_powerclamp: No package C-state available
[   10.381496] intel_powerclamp: No package C-state available
[   11.019639] Adding 2085884k swap on /dev/sda5.  Priority:-1 extents:1 across:2085884k SSFS
[   11.164752] ppdev: user-space parallel port driver
[   11.355375] iTCO_vendor_support: vendor-support=0
[   11.374881] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   11.377005] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0460)
[   11.398141] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   12.252109] floppy0: no floppy controllers found
[   13.519460] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[   13.533331] r8169 0000:02:00.0 enp2s0: link down
[   13.533349] r8169 0000:02:00.0 enp2s0: link down
[   13.533453] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[   17.519132] r8169 0000:02:00.0 enp2s0: link up
[   17.519161] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[   27.911158] random: crng init done
bengt@CNC3000:~$
  • HumanDebris
  • HumanDebris's Avatar
  • Visitor
  • Visitor
03 Nov 2017 04:13 - 03 Nov 2017 04:15 #101226 by HumanDebris
Replied by HumanDebris on topic Reliable USB WiFi?
Ok.
From What I'm seeing you are having a problem authenticating to your router, how are configuring your interface ?
What is needed is the output after plugging the wifi device.
Last edit: 03 Nov 2017 04:15 by HumanDebris.
03 Nov 2017 04:19 #101227 by tecno
Sorry but I do not understand your question.
I can surf on the web via my phone via the WiFi/Lan Devolo power plug here in the workshop.
Via wire it works as you can see here.
But connecting wire to the USB2LAN adapter = nada
It is not even recognized as I can see in top right LAN window on my desktop.
03 Nov 2017 04:23 #101229 by tecno
The very old USB-Wifi dongle Zonet ZEW2500P is found but I cannot connect.
  • HumanDebris
  • Visitor
  • Visitor
03 Nov 2017 04:23 #101230 by HumanDebris
Ok I thought you will wanting to sort out the wifi.......which I think there maybe a solution.
So USB2LAN device does not get recognised.
Ok manufacturer\model is it, does it have a FCCID on it, is ti USB2 or USB3, does your MB support the type of usb type the adapter is ?
Has the adapter been know to work on other hardware ?
  • HumanDebris
  • Visitor
  • Visitor
03 Nov 2017 04:26 #101231 by HumanDebris
OK..... you did have a wifi adapter that is loading a driver, but is not connecting. Is that the TP_link or Zonenet ?
Lets just work on one adapter at a time.
What utility are you using to config the wifi adapter ?
03 Nov 2017 04:27 #101232 by tecno
I would prefer WiFi but USB2LAN is also OK.
This USB2LAN is new purchased yesterday. Assuming it is normal USB2. Not recognized in RPi either so I have no clue.
03 Nov 2017 04:28 #101233 by tecno
OK, let us try the old Zonet that is found.
03 Nov 2017 04:30 #101235 by tecno
[  102.081669] perf: interrupt took too long (2530 > 2500), lowering kernel.perf_event_max_sample_rate to 79000
[  202.346907] perf: interrupt took too long (3165 > 3162), lowering kernel.perf_event_max_sample_rate to 63000
[  352.879348] perf: interrupt took too long (3965 > 3956), lowering kernel.perf_event_max_sample_rate to 50250
[  764.152432] perf: interrupt took too long (4985 > 4956), lowering kernel.perf_event_max_sample_rate to 40000
[ 1033.432094] usb 1-4: new high-speed USB device number 3 using ehci-pci
[ 1033.739790] usb 1-4: New USB device found, idVendor=148f, idProduct=2570
[ 1033.739799] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1033.739804] usb 1-4: Product: 802.11g WLAN
[ 1033.739808] usb 1-4: Manufacturer: Ralink
[ 1034.076074] usb 1-4: reset high-speed USB device number 3 using ehci-pci
[ 1034.405675] ieee80211 phy0: rt2x00_set_chip: Info - Chipset detected - rt: 2570, rf: 0005, rev: 0005
[ 1034.433445] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 1034.439834] usbcore: registered new interface driver rt2500usb
[ 1034.615787] rt2500usb 1-4:1.0 wlx0006f40c7d59: renamed from wlan0
[ 1034.717438] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 1034.862041] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 1035.210681] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
[ 1035.322911] IPv6: ADDRCONF(NETDEV_UP): wlx0006f40c7d59: link is not ready
bengt@CNC3000:~$
Time to create page: 0.253 seconds
