Reliable USB WiFi?
03 Nov 2017 05:10 #101247 by rodw
Replied by rodw on topic Reliable USB WiFi?
From your screen dump, what is the name of the network you wish to connect to? When you click on it, odes it give you an option to enter the passcode?
  • HumanDebris
  • HumanDebris's Avatar
  • Visitor
  • Visitor
03 Nov 2017 05:14 #101248 by HumanDebris
Replied by HumanDebris on topic Reliable USB WiFi?
In a previous dmesg dump tecno's wifi dongle tried to connect.....I did a quick search about that issue and it appears there maybe an issue with the length of the interface name & firmware. The fix I mentioned will revert back to the ethx & wlanx naming convention. I use the same options as it's easier to remember which port is eth0 rather than an name that is part driver-part mac or some formula that divides by your grandmother's maiden name.
03 Nov 2017 05:20 #101249 by tecno
Replied by tecno on topic Reliable USB WiFi?
Got 2 and both work OK when accessing via mobile phone - laptop so I have passwords OK.
  • HumanDebris
  • Visitor
  • Visitor
03 Nov 2017 05:21 #101250 by HumanDebris
Have you tried the GRUB fix yet ?
03 Nov 2017 05:22 #101251 by tecno
Never heard of, so please enlighten me.
  • HumanDebris
  • Visitor
  • Visitor
03 Nov 2017 05:24 #101252 by HumanDebris
[/ol]
I wrote about it 10 - 15 minutes ago in this thread.
forum.linuxcnc.org/pathpilot/33493-relia...wifi?start=30#101242
03 Nov 2017 05:28 #101253 by tecno
Sorry missed that totally with so many messages in rapid.
Will take a brake and have lunch and read on that topic.
Thank you for your kind help that is really appreciated.
03 Nov 2017 07:19 #101256 by tecno
boot/grub/menu.lst
No such named file can be found
  • HumanDebris
  • Visitor
  • Visitor
03 Nov 2017 16:21 - 03 Nov 2017 16:22 #101291 by HumanDebris
boot/grub/menu.lst
OK......
You really need to state the command you were trying to execute, a error msg has no meaning without context.
Usually the file is /boot/grub/menu.lst not boot/grub/menu.lst
If you are trying to edit that file you will have to do it as the superuser: ie precede the command with sudo
eg: sudo vi /boot/grub/menu.lst
vi can be replace by your favourite editor
Here is an article on temporarily editing the grub boot options.
But please precede any error msgs with the command you trying to execute. Otherwise there is no way of knowing what is producing the error message.
Last edit: 03 Nov 2017 16:22 by HumanDebris.
03 Nov 2017 16:26 #101292 by PCW
Replied by PCW on topic Reliable USB WiFi?
BTW the USB -->Ethernet dongle I use on many linux/LinuxCNC systems without issue
is on based on the Asix AX88179 chip
