Reliable USB WiFi?
06 Nov 2017 16:29 #101468 by tecno
Replied by tecno on topic Reliable USB WiFi?
1. Workshop PC
2. have to try
3. will try tomorrow afternoon
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
06 Nov 2017 17:56 #101477 by ozzyrob
Replied by ozzyrob on topic Reliable USB WiFi?
I'm in Australia...may be we could co ordinate a time so that I'm on time when you are we might get you going a bit quicker....I'm off work with a crook back (back injury) and I'm not at the mercy of any timetables.
Cheers
Rob
07 Nov 2017 01:51 #101484 by tecno
Hi Rob,
I'm in Sweden = GMT +2
Now to hospital for eyes check as I am diabetic so this a must once a year.
Cheers
Bengt
07 Nov 2017 11:52 #101499 by tecno
Just to be sure what PC are you using the office or workshop PC ?
Can you get wifi when running the from live Linuxcnc USB\CD ?
One thing you can try, when grub loads press e to edit, then on the line that loads the kernel add these options, at the end of the line is ok, net.ifnames=0 biosdevname=0
1. Workshop
2. No
3. Yes, but how to get this permanent?
If not added first line is
[FAILED] Failed to start Raise network interfaces
If added first line takes a while to process and WiFi is functional.
Cheers
Bengt
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
07 Nov 2017 15:58 - 07 Nov 2017 16:00 #101508 by ozzyrob
Sweet...Aussie slang for good
The file you want to edit is:
/etc/default/grub
The line to edit, as superuser (root), starts with:
GRUB_CMDLINE_LINUX_DEFAULT=
Add the options you typed in when booting;
Mine looks like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash net.ifnames=0 biosdevname=0"
Then run:
sudo update-grub
Next time you reboot the options should be there.
To check the command line linux booted with you can run this will show you the options passed to the kernel & boot process:
cat /proc/cmdline
Just be aware your Ethernet port will now be eth0 if you just have the one port: ie it reverts back to the older naming scheme.
Debian grub wiki page:
wiki.debian.org/Grub
Hopefully after this it should be all ok.......The TP-LINK adapter should work with this setup as well as I recall we established the driver was loaded for that dongle as well.
Last edit: 07 Nov 2017 16:00 by ozzyrob.
08 Nov 2017 02:34 #101516 by tecno
Now I am up and running!
THANK YOU
Cheers
Bengt
Time to create page: 0.098 seconds
