- Thank you received: 2100
Another plasma component...
- thefabricator03
- Visitor
7 years 4 months ago #137558
by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Phill,
This might seem like a stupid question,
With the configurator, How do I know what the Hal Pins are for the Arc ok, Ohmic Probe, Ohmic Probe enable, Float switch and Torch on.
With my basic config I have the motors jogging in the basic Axis GUI. but I dont have any of the above in the HAL or INI.
I tried using a HAL file that was posted a while ago with the Plasamc stuff in it but my basic AXIS config would not open saying it cannot find the Plasmac Hal pins.
- phillc54
7 years 4 months ago #137559
by phillc54
There is no such thing as a stupid question, sometimes there are stupid answers...
You use the HAL pin that you have wired up as that function.
e.g. In my panel I have:
arc-voltage-in = hm2_7i76e.0.encoder.00.velocity
float-switch = hm2_7i76e.0.7i76.0.0.input-08-not
torch-on = hm2_7i76e.0.7i76.0.0.output-00
Cheers, Phill.
Cheers, Phill.
- thefabricator03
- Visitor
7 years 4 months ago #137686
by thefabricator03
I am getting a error message when I try to start the Plasmac config I create with the configurator,
IOError: [Errno 2] No such file or directory: 'pyvcp-panel.xml'
Am I missing a dependency? I can open the Sim version of the branch.
- phillc54
7 years 4 months ago #137687
by phillc54
If you ran pncconf you must have selected to use a pyVCP panel.
You need to comment that out in your ini file or copy pyvcp-panel.xml from your base machine config directory to the new plasmac config directory.
Cheers, Phill.
Cheers, Phill.
- Thank you received: 4153
7 years 4 months ago #137689
Just remember that Plasmac is trying to do what no other example config does and build a working config for you. If things don't work out, its a good idea to compare your ini file with the one in the sim and see what has changed.
phillc54 wrote: If you ran pncconf you must have selected to use a pyVCP panel.
Cheers, Phill.
- thefabricator03
- Visitor
7 years 4 months ago - 7 years 4 months ago #137695
by thefabricator03
I am sure this has been covered before but the last half and hour searching has not found the solution,
I have plasmac working but I cannot get the arc voltage to work.
I have FOUT - and FOUT + from the THCAD to encoder input A (TB3, Pin 7,
I have set in the configurator mode 1, and set the arc voltage input to hm2_7i76e.0.encoder.00.velocity,
The THCAD is set to Unipolar and the yellow light blinks quicker when I fire the torch.
Any ideas what I am doing wrong?
Last edit: 7 years 4 months ago by thefabricator03.
Time to create page: 0.250 seconds
