- Thank you received: 7491
Another plasma component...
Hmmmmm not exactly, I said in general I am wary of not typing my info on web sites, the usual network admin paranoia. In your case I literally saw your personal phone number and thought " oh good I'll call him tomorrow! "rodw wrote:
Well its been an eventful night! I was blessed by a phone call from Tommy which was nice. He was a bit worried about security if he contacted me via my web site but rest assured we use a leading, highly secure cloud hosted ecommerce provider called neto which is 51% owned by Telstra, our monopolistic telecommunications giant here in Australia. If they have any security gaps, the whole country will be in trouble!
Regards,
Tom
P.S.
Just did a short video about Mesa 7i92 and an Acer laptop that works perfectly with Linuxcnc even when wired through a network switch, uploading it to YouTube and starting a new thread for more info.
- Grotius
- Thank you received: 2349
You can post your code over here. G90 is good.
I and J offset's are the core members to be calculated when using snippet's for circles and arc's in all 4 quadrant's.
If it's G90.1 or G91.1 does not matter for me at this moment.
I have not looked so far myself to load in g-code line's into the real time memory and do some calculation's with it relating to code snippet's. But it's overall a interesting item. The probe over distance has also become a very succesful item. So why not adapt some code snippets.
The only worry i have is to keep it a real time interacting solution (component solution)
I don't like pre defined g-code solution's like multiple g-code lines for a simple probing sequence etc.
Then user cannot change it real time in the field at the machine.
- phillc54
- Thank you received: 2100
To use this do an upgrade then edit your ini file.
For Axis, the panel sits at the right hand side and at the moment you will get a permanent error in the terminal saying it is waiting for a component to be ready. This doesn't appear to affect the machine operation and there is a pull request in the LinuxCNC repo for a fix.
Comment out the two EMBED lines an uncomment the GLADEVCP line.
For Gmoccapy the panel sits at the left hand side.
Comment out the first three EMBED lines and uncomment the next three EMBED lines.
Axis:
Gmoccapy:
Cheers, Phill.
- Thank you received: 4153
Just a heads up you may need to manually copy the new display settings into your ini file. I was getting gcode errors becasue I did not have a feed rate because the whole plasma run tab was missing! The new Gmoccappy wide screen works well.
The other issue I had was that the new HAL connections to allow adaptive feed and disableTHC features.
Anyway, the good news is once I had pins that actually got the adaptive feed working, I sorted out some code snippets and cutting rules for holes for Sheetcam and it all works nicely.
- thefabricator03
- Visitor
rodw wrote: Anyway, the good news is once I had pins that actually got the adaptive feed working, I sorted out some code snippets and cutting rules for holes for Sheetcam and it all works nicely.
Rod,
Do you mind sharing your sheetcam post for Plasmac that has the new disable function.
Rod,
Yes, I will when I'm back at work. I did not change much today, the magic is in the cutting rules., not the post processor.
