Another plasma component...
7 years 4 months ago #136944 by islander261
Replied by islander261 on topic Another plasma component...
Phill
Thank you.
Why buy a brand name system for other than paid support help? Plasmac does it all!
The following user(s) said Thank You: phillc54, rodw
7 years 4 months ago #136945 by rodw
islander261 wrote: Phill
Thank you.
Mind you why do you need paid support when you have forum members like you, Phill, Tommy, Grotius et al?
Because I don't use my table every day, its the simple stuff that catches me out and would annoy the support agents no end. Like forgetting to connect the earth lead and wonder why the ArcOK does not come on.... I'm that used to doubting my skills as a builder.
The following user(s) said Thank You: phillc54, tommylight, Grotius
7 years 4 months ago - 7 years 4 months ago #136957 by phillc54
Sorry about the earlier post, I pushed this update but I had it wrong so we are good to go now and I have pushed the fixes.
This update adds a feed-reduction pin to the component which I have tied to motion.analog-out-03 in the configs.
The value you set the pin to sets the velocity to the percentage of the displayed value in the cut parameters (almost).
M67 E3 Q0 sets the velocity to 100%
M67 E3 Q10 sets the velocity to 10%
M67 E3 Q50 sets the velocity to 50%
M67 E3 Q100 sets the velocity to 100%
The minimum percentage allowed is 10%, values below this will set the percentage to 100%
The maximum percentage allowed is 100%, values above this will set the percentage to 100%
The reason for Q0 equating to 100% is so that if the user decides not to implement this feature then no changes are necessary.
If you intend to use this feature it would be prudent to add **M67 E3 Q0** to your gcode preamble and postamble so you start and end at a known state.
Cheers, Phill.
Last edit: 7 years 4 months ago by phillc54. Reason: Typos, should be Q, not P
7 years 4 months ago #136958 by phillc54
I would like to gradually build the readme into a reasonable sort of document as for the foreseeable future it will be the single source for documentation.
It is located here
If you see something that is wrong or missing let me know and I will edit it.
Contributions would be most welcome...
Cheers, Phill.
7 years 4 months ago #136960 by rodw
Phill, thanks again for all of your hard work and now finishing off this system so it is now truly the best kick ass system on the market. Pretty sure that this will see a few overpriced THC solutions disappear from the market place once word gets out and you get it into V 2.9! I'll try and give it a burl tomorrow.
Based on a promise on this thread I'm getting close to finishing a google drive document which I will share with you and John for feedback and revision when I get it written. Its a background document about plasma, and is not designed to be a manual for Plasmac. Its sitting on 9 pages of info at the moment. I'm kinda hoping it can be deployed to V 2.9 docs from your repo....
7 years 4 months ago - 7 years 4 months ago #136961 by phillc54
Rod,
It is great that you are doing those docs, I was intending to put some basic plasma stuff in the readme but it would be better to just provide a link to your docs and save me a lot of hassle. I find it really difficult to write docs. Anyhow we can sort that out when your docs are finished.
If you are doing that amount of work then you should do it all via GIT so you can submit a PR to get it included then you can get the credit for the commit, which is deserved. I can help a bit with that if you want.
Cheers, Phill.
Time to create page: 0.202 seconds
