- Thank you received: 32
Another plasma component...
- JTknives
- Thank you received: 7491
- phillc54
- Thank you received: 2100
rodw wrote:
Yes Rod I sure will. The default will be disabled. It is only for those of us that don't have that feature available in a post processorphillc54 wrote: Phill, if you come back to this, could you make sure there is something that can disable this parsing? Somehow, it does not feel right to build features that modify the Gcode as a user might not want to enable this type of behaviour.
- grijalvap
- Thank you received: 63
thanks for your help.
Attached is the last version of the component I'm Using to communicate with the Hyperterm 85 plasma
please feel free to use, modify and distribute it.
Also let me know if you have any doubt about the code, or how I use it
thanks.
- islander261
- Thank you received: 216
I have a setup similar to Rod's and find it works very nice. I can use it to square the work piece to the machine motion and set the work piece zero. My cross hairs intersect under the nozzle of my torch. I seem to remember using two $5 laser line generators from ebay. I am sure there is a photo of my setup someplace in this forum topic.
Pedro
Thank you for sharing.
- Thank you received: 4153
grijalvap wrote: Hi
thanks.
Phill, it would be cool to include this in your distro so it becomes part of Linuxcnc. I'm not sure how you go about writing man pages for python user space components.
