- Thank you received: 4153
Another plasma component...
7 years 3 months ago #140936
No eBay APP ID and/or Cert ID defined in Kunena configuration
To square the cross hairs you just need to make an L shaped cut, place over the corner and align the crosshairs. The basic 5 volt laser modules are < usually $5.00 on ebay. Something like this
I just thought using 2 line lasers intersecting under the tip like John does was too much work! There are plenty of examples on you tube
islander261 wrote: JTknives
I have a setup similar to Rod's and find it works very nice.
7 years 3 months ago #140953
I think you just need to write an asciidoc documentL
github.com/LinuxCNC/linuxcnc/blob/master...rc/drivers/vfs11.txt
is an example.
Then add it to the submakefile:
github.com/LinuxCNC/linuxcnc/blob/2.8/docs/src/Submakefile
Replied by andypugh on topic Another plasma component...
rodw wrote: I'm not sure how you go about writing man pages for python user space components.
is an example.
- robertspark
- Thank you received: 216
7 years 3 months ago - 7 years 3 months ago #140962
by robertspark
Replied by robertspark on topic Another plasma component...
Last edit: 7 years 3 months ago by robertspark.
- phillc54
- Thank you received: 2100
7 years 3 months ago #140979
by phillc54
It's a neat conversion he did on
this thread
The following user(s) said Thank You: robertspark
- robertspark
7 years 3 months ago #140985
by robertspark
thanks very nice
- phillc54
7 years 3 months ago #140994
by phillc54
I have pushed an update:
Add small hole feature to the GCode parser
This is only for folk who don't use a post processor or their post processor cannot do small hole stuffs...
home.iprimus.com.au/phillcarter/plasma/p...#_hole_cutting_intro
Time to create page: 0.558 seconds
