Another plasma component...
7 years 7 months ago - 7 years 7 months ago #129956 by phillc54
John,
There is a problem with the current setting of thc-enable and cut-height from gcode in that if you connect an analog or digital out to one of the new hal pins then they cannot be set from the GUI as they are outputs.
I have just pushed a version (Gmoccapy only at this stage) that does it by remapping M10 (currently unused) which seems to work ok.
P and Q arguments are used to achieve this
P0 = thc-enable, Q0 disables and Q>0 enables
P1 = cut-height, Qnnn. is the height
A code other than M10 could be used, I only picked it because it was unused and I didn't want to remap the digital/analog codes in case a user required them.
Edit: actually after re-reading the docs they cannot be remapped anyway...
Cheers, Phill.
Last edit: 7 years 7 months ago by phillc54.
7 years 7 months ago #129972 by islander261
Replied by islander261 on topic Another plasma component...
Phill
Thank you for all the effort on the cutting control from Gcode. I will look at the code in a few days. The analog output was chosen because others had used them in past. One of the original ways cutting parameters were passed was using the S spindle speed word in Mach3, no analog codes there. At one time there was a short lived discussion here about creating a loose "standard" of codes used for cutting parameter control from Gcode, I just ended up using the same codes as CandCNC does. I really will not be able to work on this until Tuesday or Wednesday when the forecast is for rain. Too much outside related stuff at this time of year to work inside during dry weather. I will start porting over my hal files so I can drive the machine. Is the M10/M11 pair of codes usually used as fast on and fast off for lasers?
Guys
The guided cylinders do look like a nice starting point for a floating head, unfortunately I already have one that works. What is really needed is a good reliable non contact method to find the top of the material. I am guessing that since none of the big commercial machine builders are doing this for plasma there must be a good reason. I certainly will not be installing a crazy noisy pneumatic plate marker any time soon. My compressor lives outside to try and control the noise in the shop and I still need to wear hearing protection when cutting because of the exhaust fans.
7 years 7 months ago #130014 by phillc54
That is probably correct, I also see that Hypertherm and Thermal Dynamics use M10 to turn Marker off. It would be good if there were some sort of consensus and what codes to use.
I have done some preparatory work to allow other overrides from gcode, I have done all the coding for this in Gmoccapy but have not mapped them to any M codes yet, looking at this table leads me to think I should stay away from codes in the 00-99 range as these may be used internally for LinuxCNC at a later date. I may just use some code/codes in the high 800's. I am also unsure if I should use a single M code with P and Q words, P being the item and Q being the value or whether to allocate one M code to each item and use the P word for the value...
The items I have overrides for are:
material, thc-enable, use-auto-volts, pierce-height, pierce-delay, cut-height, cut-feed-rate, cut-amps, cut-volts, puddle-jump-height and puddle-jump-delay
There are no real overheads to doing this so more items could easily be added if required (or deleted if you think I have gone crazy)
The only items mapped to M codes at the moment are thc-enable and cut-height as mentioned in this previous post.
Cheers, Phill.
7 years 7 months ago #130025 by Mike_Eitel
Replied by Mike_Eitel on topic Another plasma component...
Probably the wrong place to ask a question:
I'm not in plasma and think I'll never be but curious.
As I know plasma emits a lot of uv light. And I'm convinced there must be a relation between distance and light emissions. Did anybody tried to measure and control via that aspect ?
7 years 7 months ago #130035 by islander261
Phill
Those that have newer HT machines will be able to use your work with Pedro's RS-485 work to have full control over their plasma power supply from Gcode. I believe that the lower numbered M codes (99-199) are reserved for some sort of internal LinuxCNC use so a set of high numbers is good. There is one thing that I forgot to mention. I think one of the reasons the analog output codes are used is that you can synchronize them with machine motion so you can output changes that don't stop machine motion. I know that my use of them is done so that the THC enable command is synchronized with the start of X&Y motion to not break the motion buffer. THC disable is just a normal asynchronous code because it usually occurs after a M5. The exact format of the codes doesn't matter much from where I sit, after all the PP does all the work inserting them after you have written it.
Mike
Thanks for adding to the discussion. I am sure that someone who isn't into plasma cutting will be able to see the forest for the trees. Right now most use the arc voltage to sense the torch height for a given cutting speed and current. The present discussion was about finding the top of the work piece so that accurate pierce and initial cut height can be established, typically the torch isn't on when this happens.
7 years 7 months ago - 7 years 7 months ago #130052 by rodw
Mike_Eitel wrote: Probably the wrong place to ask a question:
I think voltage is probably the best way as its much easier to measure. In my tests where I logged 16,000 readings with halsampler at different heights, the linear relationship between height and voltage was accurate with 99.4% confidence. I measured 7.53 volts per mm.
Last edit: 7 years 7 months ago by rodw.
Time to create page: 0.700 seconds
