Another plasma component...
31 Mar 2019 20:30 #130054 by Mike_Eitel
Replied by Mike_Eitel on topic Another plasma component...
I was wondering what is if you pas an already done cut. There I would gues a difference between voltage and emitted light. Just m5c.
P. S.
Tried to find a better distance measuring for my 3D printer in Marlin for bed leveling and gave up after some crazy ideas that did not work.
For plasma distance I'd try some triangulating lasers on first thought but expect uv light problems after ignition.
31 Mar 2019 21:07 #130058 by PCW
Replied by PCW on topic Another plasma component...
I think one reason plasma voltage is the most common torch height sensing method
is that the environment near the torch is so nasty in terms of electrical noise and particulate matter that optical systems would tend to have a short lifetime.
That might be soluble with clean air purging of the optical path however
I do wonder if initial height sensing could be done with a sensitive back pressure sensor (inches of water) with a low (sensing) air flow rate
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
01 Apr 2019 05:02 #130068 by phillc54
It appears that hal pins cannot be read or set from python while a program is running and this causes problems with the way I have done gcode overrides.
I am going to have to completely rethink how to achieve this so I will need to strip all this related code out of the repo.
I will post again when I have finished this.
Cheers, Phill.
01 Apr 2019 08:26 #130082 by rodw
Phill, I vote and I am sure that John will second the motion that motion.annalog-00 is reserved for plasma operations.
This component to enable and disable THC operation is part of it
forum.linuxcnc.org/plasma-laser/32700-co...hc-from-within-gcode
This gmoccappy python file has a decode from file option that John came up with at around line 366
It is possible to fold a number of functions into this sinfgle analog pin if the most significant digit (or a numeric range) is used to denote the function and the rest of the number the relevant setting value.
File Name: plasma.py
File Size:21 KB
 #ISLANDER - this function is used to decode command from gcode file
   # if real time control of height hold is desired then 1X and 2X need to be
   # decoded in a realtime component
    def on_new_command_from_file(self, hal_pin, data = None):
        if hal_pin.get() != 0:
             command = hal_pin.get()
             #THC run from file
             if 20 <= command < 30:
                    self.halcomp["lock-height-from-file"] = False
                    #no need to decode I% here no Hypertherm RS-485
             # height hold from file
             elif 10 <= command < 20:
                    self.halcomp["lock-height-from-file"] = True
             #global THC on
             elif 900 == command:
                   self.hal_btn_THC.set_active(True)
             # global THC off
             elif 999 == command:
                   self.hal_btn_THC.set_active(False)
              #get arc voltage
             elif 360 <= command < 400 or 3060 <= command < 3201:
                   if command >= 3060:
                        command = command - 3000
                   else:
                   self.halcomp["target-voltage"] = command
                   self.lbl_prog_volt.set_label("%d" % command)
             #get preset Amps not actually used
             elif 410 <= command < 500 or 4000 <= command < 4201:
                   if command >= 4000:
                        command = command - 4000
                   else:
                   #nothing else to do here for now
             #get arc servo delay time
             elif 50 <= command < 60 or 500 <= command < 600:
                   if command >= 500:
                        command = (command - 500)
                   else:
                        command = command - 50
                   self.adj_THC_delay.set_value(command)
             #get THC tune
             elif 710 <= command < 720:
                   command = command - 710
                  #nothing to set yet
             elif 80 <= command < 90 or 800 <= command < 900:
                   if command >= 800:
                        command = (command - 800)
                   else:
                        command = command - 80
                   self.adj_pierce_delay.set_value(command)
Remember that the python code is in user space hence the component to enable and disable the THC is in real time.
  • phillc54
  • Platinum Member
  • Platinum Member
01 Apr 2019 08:46 #130084 by phillc54
OK, everything is back how it was...
rodw wrote:
This component to enable and disable THC operation is part of it/quote]
Thanks Rod, I will have a good look at this tomorrow.
Cheers, Phill.
01 Apr 2019 13:18 #130093 by andypugh
Replied by andypugh on topic Another plasma component...
How are you reading HAL pins?
If your python code creates its own HAL pins, and those are linked in HAL, then they will update in hard real time.
(Though the Python code itself will not be running in real-time)
01 Apr 2019 15:43 #130105 by Zultan
Replied by Zultan on topic Another plasma component...
Hi Phil, thanks for your amazing work on this component. I have been running it on a my plasma for about a week and everything seems to be working well functionality wise. I had a few problems converting it over to a real machine which I think may be bugs. (For reference I am running Axis gladevcp with a hypertherm powermax 45 and Proma THC. )
  1. Axis starts up in mode=0 even though I set MODE=2 in the plasmac.ini. I got around this my manually setting the pin in the plasmac.hal with:
    setp plasmac.mode              2
  2. I have problems saving values entered into the configuration tab (probe speed, pierce height, etc). If i manually edit the .cfg file and restart linuxcnc I can see that the values update however the save button doesn't seem to work. (This may be me not understanding how to configure everything)
  3. If the table is setup to have homing switches and software limits on the z axis. If you use a work offset (g54 in his case) and touchoff a little way above the material the torch will not be able to probe down and will instead give an error because of:
    net p_comp:axis-min-limit           ini.z.min_limit                 =>  plasmac.axis-z-min-limit
    I'm not sure of the expected behavior here so i simply:
    sets p_comp:axis-min-limit -50
    and assume that the software limits will stop the torch from traveling past the table's z.min_limit.
    Thank you for all your hard work, the code you created is very well organised and well written. I found working with it very easy and intuitive.
01 Apr 2019 15:44 #130106 by islander261
Replied by islander261 on topic Another plasma component...
Guys
I have changed the way the way I decode the M67, M68 commands from Gcode. I now use a hal component to get the changes and use the python handler to update the screen state. I will post the code when I get out to the shop. The usual warnings, it works well enough for me but may contain logic errors that cause bad things with corner cases.
01 Apr 2019 19:08 #130114 by islander261
Guys
Here is what I do right now. The only parameters I actually change from Gcode are the global THC enable and the THC servo enable. The global THC enable isn't needed unless you want to switch on an external THC controller. So the connection from Gcode is:
# hook up command from Gcode
net gcode-command     <= motion.analog-out-00
net gcode-command     => plasma_tab.Command-From-File
And the connections to the real time decode bit:
#get gcode file commands connected
net gcode-command        => decode-gcode-file-cmds.command-value
net gcode-servo-enable   <= decode-gcode-file-cmds.gcode-servo-enable
net gcode-global-THCon   <= decode-gcode-file-cmds.gcode-global-THCon
#get gui command source switch
#net use-control-params   <= plasma_tab.use_control_params
#OR THC on sources
net gcode-THCon          => or2.global-THCon.in0
net THC_enable_link_main => or2.global-THCon.in1
net mixed-THCon          <= or2.global-THCon.out
#AND gcode THCon
net gcode-servo-enable   => and2.THCon.in0
net gcode-global-THCon   => and2.THCon.in1
net gcode-THCon          <= and2.THCon.out
#select THC enable source
net mixed-THCon          => mux-gen.00.in-bit-00
net THC_enable_link_main => mux-gen.00.in-bit-01
net use-control-params   => mux-gen.00.sel-bit-00
net selected-THCon       <= mux-gen.00.out-bit
#interlock THC servo enable with arcok signal
net arcok                => and2.thc-enable.in0
#net THC_enable_link_main => and2.thc-enable.in1
net selected-THCon      => and2.thc-enable.in1
net switched-arcok       <= and2.thc-enable.out
Sorry the code is such a mess, I get pretty random at times. The real time decoder is needed to make it work when a Gcode file is running for some reason the python to hal connection misses most of the changes then. At least I couldn't get to work reliably without the real time component.
  • phillc54
  • Platinum Member
  • Platinum Member
01 Apr 2019 22:52 #130120 by phillc54
I am trying to detect a change in a HAL pin from python using hal.get_value().
I will try later today using halcmd from popen.
That seems similar to what I am seeing.
Zultan,
Thanks for the feedback. I will have a look at these issues after I sort out this issue I am working on.
Cheers, Phill.
Time to create page: 0.881 seconds
