- Thank you received: 3
Another plasma component...
- Zultan
7 years 7 months ago #130105
by Zultan
Replied by Zultan on topic Another plasma component...
Hi Phil, thanks for your amazing work on this component. I have been running it on a my plasma for about a week and everything seems to be working well functionality wise. I had a few problems converting it over to a real machine which I think may be bugs. (For reference I am running Axis gladevcp with a hypertherm powermax 45 and Proma THC. )
- Axis starts up in mode=0 even though I set MODE=2 in the plasmac.ini. I got around this my manually setting the pin in the plasmac.hal with:
Code:setp plasmac.mode 2
- I have problems saving values entered into the configuration tab (probe speed, pierce height, etc). If i manually edit the .cfg file and restart linuxcnc I can see that the values update however the save button doesn't seem to work. (This may be me not understanding how to configure everything)
- If the table is setup to have homing switches and software limits on the z axis. If you use a work offset (g54 in his case) and touchoff a little way above the material the torch will not be able to probe down and will instead give an error because of:
I'm not sure of the expected behavior here so i simply:Code:net p_comp:axis-min-limit ini.z.min_limit => plasmac.axis-z-min-limitand assume that the software limits will stop the torch from traveling past the table's z.min_limit.Code:sets p_comp:axis-min-limit -50
Thank you for all your hard work, the code you created is very well organised and well written. I found working with it very easy and intuitive.
- islander261
- Thank you received: 216
7 years 7 months ago #130106
by islander261
Replied by islander261 on topic Another plasma component...
Guys
I have changed the way the way I decode the M67, M68 commands from Gcode. I now use a hal component to get the changes and use the python handler to update the screen state. I will post the code when I get out to the shop. The usual warnings, it works well enough for me but may contain logic errors that cause bad things with corner cases.
- islander261
7 years 6 months ago #130114
by islander261
Guys
Here is what I do right now. The only parameters I actually change from Gcode are the global THC enable and the THC servo enable. The global THC enable isn't needed unless you want to switch on an external THC controller. So the connection from Gcode is:
And the connections to the real time decode bit:
Sorry the code is such a mess, I get pretty random at times. The real time decoder is needed to make it work when a Gcode file is running for some reason the python to hal connection misses most of the changes then. At least I couldn't get to work reliably without the real time component.
# hook up command from Gcode
net gcode-command <= motion.analog-out-00
net gcode-command => plasma_tab.Command-From-File
#get gcode file commands connected
net gcode-command => decode-gcode-file-cmds.command-value
net gcode-servo-enable <= decode-gcode-file-cmds.gcode-servo-enable
net gcode-global-THCon <= decode-gcode-file-cmds.gcode-global-THCon
#get gui command source switch
#net use-control-params <= plasma_tab.use_control_params
#OR THC on sources
net gcode-THCon => or2.global-THCon.in0
net THC_enable_link_main => or2.global-THCon.in1
net mixed-THCon <= or2.global-THCon.out
#AND gcode THCon
net gcode-servo-enable => and2.THCon.in0
net gcode-global-THCon => and2.THCon.in1
net gcode-THCon <= and2.THCon.out
#select THC enable source
net mixed-THCon => mux-gen.00.in-bit-00
net THC_enable_link_main => mux-gen.00.in-bit-01
net use-control-params => mux-gen.00.sel-bit-00
net selected-THCon <= mux-gen.00.out-bit
#interlock THC servo enable with arcok signal
net arcok => and2.thc-enable.in0
#net THC_enable_link_main => and2.thc-enable.in1
net selected-THCon => and2.thc-enable.in1
net switched-arcok <= and2.thc-enable.out
- phillc54
- Thank you received: 2100
7 years 6 months ago #130120
by phillc54
I will try later today using halcmd from popen.
Zultan,
Thanks for the feedback. I will have a look at these issues after I sort out this issue I am working on.
Cheers, Phill.
I am trying to detect a change in a HAL pin from python using hal.get_value().andypugh wrote:
How are you reading HAL pins?
Zultan,
Cheers, Phill.
- islander261
7 years 6 months ago #130129
by islander261
Guys
I had a good go at getting this branch to run this evening. Still have some work to do. What works:
1. Machine comes out of e-stop and turns on.
2. Machine homes on all three axis.
3. Pendant mostly (as much as I use it) works for jogging X & Y axis. I had to do a bit of a hack on plasmac.hal to add some OR2 instances to share program command halui inputs. Didn't try any of the MDI buttons.
4. Manual jogging works on X&Y axis with correct DRO function.
5. Really couldn't get a clean connection to my hardware input pins in plasmac.hal. Had to net 7i76e input pins in another .hal file and then use those nets in plasmac.hal. Output hardware pins worked as expected. Note that I do use the ...-not pins to get true logic and that seemed to be the problem.
What doesn't work at this point:
1. Jogging z axis(manual or pendant). If I jog a very small distance from Z home a soft limit error occurs. My Z soft limits are +.25" and -3.65". My Z home is .050" below the soft limit. Normal work piece zero will be about -2.9" to -3.5" machine position. My machine is like a mill in that machine Z zero is at the top (away from work piece) of axis travel.
2. Z DRO does not respond when jogging. Back plot screen graphics show Z jogging movement. Z DRO shows movement while homing. Z DRO follows work piece (G54) offset adjustment.
3. Editing and updating material and configuration files doesn't seem quite right. Still can't get addition materials to display even though they are in the file. Some of the GUI values don't save to the files, always get the old defaults on startup.
How do I do a test probing so I can check how well the IHS is doing? On my present system where everything is controlled through Gcode it have short program to do this.
I will have to change the plasma control glade panel so that it is on tabs behind the back plotter (more GMOCCAPY like) to free up more space. I am pretty sure I will end up needing to change the functions of the current home axis buttons, that is something I never have a reason to use.
- phillc54
7 years 6 months ago #130135
by phillc54
John,
Are you running the config from your git clone or is it a copy in another folder?
Cheers, Phill.
Cheers, Phill.
Time to create page: 0.457 seconds
