- Thank you received: 4153
Another plasma component...
This config is just so complete and neat and tidy and works far better than anything I've written in the last 3 years. Well done! I'm sold on this already.
I'll upload a video to my build thread.
The Linuxcnc set should be very grateful for your tireless work on this. I only hope it makes its way to master branch soon. I think its getting a head of steam now so with a few installations, the bugs will get found quickly.
One observation is restarting on a pause is problematic as there is no steel left to support an arc on my machine but it tries valiantly to get going again!
- islander261
- Thank you received: 216
I find that on my machine restarts are very dependent on the consumables I am using (at least on thin sheet). I also think this can be expanded and say it is a kerf width * material thickness^-1 related. I cannot restart in a cut with stock Duramax consumables but I can restart in the cut all day with Finecut consumables.
BTW when I used the TD torch I would slip a small scrap of really thin sheet over the cut and that would solve the arc starting problems.
- Thank you received: 7491
That is exactly what is needed sometimes for thin materials ! Works always.islander261 wrote: BTW when I used the TD torch I would slip a small scrap of really thin sheet over the cut and that would solve the arc starting problems.
- xunil
I do have a question, though: can the plasmac component (and associated config) be used without any form of probing? Our machine uses a Hypertherm T45m machine torch, which doesn't appear to have any facility for ohmic probing, and our torch carriage doesn't have a float switch. We're investigating adding both, but I'm hoping I can try out the plasmac component without these. Height setting will be accomplished with gauge blocks and very small manual jogs instead.
Many thanks to Phill for writing the component and to all of the eager testers - I hope to join your ranks soon!
- phillc54
- Thank you received: 2100
I'm probably talking out of my hat here but would it be possible to move forward just a tad using paused motion and starting there similar to an edge start.rodw wrote:
Cheers, Phill.
- phillc54
No, it's not possible with the current component. It probably could be done but it's not really something that I would encourage.xunil wrote:
Cheers, Phill.
