Another plasma component...
7 years 6 months ago #131274 by phillc54
In my 'cleaning' up I managed to disconnect the ohmic and float pins...
So I have tested Axis and Gmoccapy in metric and imperial with Z zero at bottom and Z zero near top and all were successful with the current version of the branch.
Cheers, Phill.
7 years 6 months ago #131352 by phillc54
In this post I asked about resetting offsets at the end of each job.
I think I am going to go with this unless there are valid reasons not to as it means keeping track of the Z axis is much neater.
Cheers, Phill.
7 years 6 months ago #131354 by tommylight
Replied by tommylight on topic Another plasma component...
Whatever you decide is good for me, mainly because i am not helping lately ( sorry about that ), and i can see pros and cons of both versions, but i am also leaning towards the one you chose.
7 years 6 months ago #131367 by islander261
Replied by islander261 on topic Another plasma component...
Phill
Thank you, I did successful line testing today. As usual nice cut quality from Plasmac, no surprises. The weather is supposed to be dry tomorrow so I will need to do yard work, no cutting. Hopefully Monday or Tuesday I will do a few production sheets when the weather is wet again.
My Gmoccapy using my complex PP and Gcode files resets the offsets at the end of every file so you always start in a known state when loading the next file without having to re initialize the machine.
7 years 6 months ago #131369 by phillc54
I pushed another update:
- remove duplicated ini file entry - doesn't really affect anything, just a tidy up
- change resolution for arc voltage input scaling and offset
GUI files changed are:
configs/sim/axis/plasmac/native/plasmac_axis.py
configs/sim/axis/plasmac/gladevcp/plasmac_panel.py
configs/sim/gmoccapy/plasmac/plasmac_config.py
configs/sim/gmoccapy/plasmac/plasmac_panel.py
rodw wrote:
The on screen scaling does not work because of enforced upper and lower limits in the config screen as I can't enter an offset of 3659.375 (0-100 enforced)
Also the maths in my earlier post says the frequency counts per volt is 83.73 and you have to input the reciprocal of this which is 0.011943151 which is not logical. So I would recommend that the maths be changed to do the reciprocal stuff internally and also remove the enforced range on the scale. If that was the case I think it would work well with some explanation in the docs.
I have fixed the upper and lower limits, hopefully by enough to cover everything.
I don't want to change too much as I don't want the component itself to be dependent on any particular hardware.
I rigged up a 7i76e with a TCAD connected to the encoder input and two batteries for testing:
- run LinuxCNC
- open halshow and watch plasmac.arc-voltage-in and plasmac.arc-voltage-out
- set arc-voltage-scale to 1
- set arc-voltage-offset to the value read from plasmac.arc-voltage-in
- measure battery voltage
- connect battery to THCAD input
- set arc-voltage-scale to battery-voltage / plasmac.arc-voltage-out
could probably fine tune further but it was good enough for the purpose of the exercise.
My values were:
arc-voltage-offset = -3805
arc-voltage-scale = -0.000406
Cheers, Phill.
7 years 6 months ago #131370 by rodw
Forgot mention, the only real issue was the ability to set the offset > 100
At 0 volts, with zero as an offset, I was getting 44 volts and 3659/83.73 = 43.7 volts so the logic was correct.
I'll update and give it a go when I'm next up in the shed.
Time to create page: 4.755 seconds
