Another plasma component...
19 Apr 2019 03:53 #131209 by rodw
OK, it seems I should use
arc_voltage_scale = (28778.125 - 3659.375) / 300 = 83.73
so then I think that means the
arc_voltage_in = hm2_7i76e.0.encoder.00.velocity
Is that what you were thinking?
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
19 Apr 2019 03:57 #131210 by phillc54
Yes, the intent was to use the encoder velocity similar to JT's thc component.
Did I forget to document that?
Cheers, Phill.
19 Apr 2019 04:25 - 19 Apr 2019 04:33 #131211 by islander261
Replied by islander261 on topic Another plasma component...
Rod
I recall that you use a custom component to do your encoder.velocity to displayed arc voltage conversion. If this is still the case you just need to input a scale of 1 and an offset of zero. I actually use the scale hal component to scale mine so I just use a config scale value of 1 and offset of 0. Your making this way harder than it needs to be for what you have gotten working before. You want to use plasmac mode 1 for THC. Look at the examples I posted for others. At this stage of the game with frequent updates I am putting all my machine specific .hal connections in my machine.hal file (well most of them, the pendant introduces it's own problems).
Phill
Ok, I am not going crazy looking for a configuration problem. My machine Z zero is at the top of the Z axis travel like a milling machine, the work piece Z zero (G54 Z) is the top of the work piece. I need a Safe Z that is about 1" above the work piece to miss tip ups ( and a probe distance of up to 1.25" for really thick plate). In my mind you always want the machine to reference against a known machine location (home switch or other) and not against a variable part like slats (not a true unmovable surface like a milling machine table). I have no idea how to tram a torch against a floppy set of slats. I am well aware of the legacy work around done by all the plasma table people that used Mach 3 and couldn't properly home the Z and find a work piece surface by probing. There is no reason to do this with LinuxCNC, if you use Gcode we can use G38.x probing or directly set the G54 Z offset from a probing part of a .hal component. So my .ini Zmax value is .25" and my .ini Z min value is -3.125, of course these are in machine (G53) values as all soft limits are.
I actually do use XYYZ layout for my configuration.
Last edit: 19 Apr 2019 04:33 by islander261.
19 Apr 2019 04:26 #131212 by rodw
Either way I was right. :) the term voltage is confusing when entering a frequency. But I was studying it all in an armchair. Now back in front of a machine.
  • phillc54
  • Platinum Member
  • Platinum Member
19 Apr 2019 04:35 - 19 Apr 2019 04:39 #131213 by phillc54
OK, that explains a lot, I have my milling machine Z zero at the table so my Z max is top of Z travel....
I have done all this work using the same setup so it looks like I need to change a few things to suit both setups.
I don't measure anything from the slats, I just think that should be the bottom soft limit or thereabouts.
I am happy for you to find configuration problems so long as it doesn't put you off doing more testing.
I will switch my test rig coordinates around and sort it out...
Cheers, Phill.
Last edit: 19 Apr 2019 04:39 by phillc54.
19 Apr 2019 05:20 #131214 by rodw
I'm on a bit of a roll here. Got the machine up but have not moved it yet. I found I had a few signals previously defined to deal with my flashing warning lights and stuff like that. So I've been editing the plasmac.hal file (see attached).
The on screen scaling does not work because of enforced upper and lower limits in the config screen as I can't enter an offset of 3659.375 (0-100 enforced)
Also the maths in my earlier post says the frequency counts per volt is 83.73 and you have to input the reciprocal of this which is 0.011943151 which is not logical. So I would recommend that the maths be changed to do the reciprocal stuff internally and also remove the enforced range on the scale. If that was the case I think it would work well with some explanation in the docs.
So for now I'll revert to my scalethcad component. It is now quite sophisticated with averaging and stuff built in but the doc side of it needs cleaning up.
19 Apr 2019 05:22 #131215 by rodw
Also the default of the plasmac test screen is annoying when you are trying to work on the forum at the same time. I found adropdown to disable it but not sure if it can be turned off when loaded.
  • phillc54
  • Platinum Member
  • Platinum Member
19 Apr 2019 05:23 #131216 by phillc54
Rod,
You can comment it out in the ini file
Cheers, Phill.
19 Apr 2019 06:25 #131217 by rodw
Well it seems to be up and running. !!!
I pulsed the torch and flames spewed forth!
Reverted to my scaling component
I just have to work out why my pendant is not going and why my orange warning light is not coming on but thats not a plasmac issue.
Also found a fault on my Z axis homing to a shared home/limit switch as it was missing HOME_IGNORE_LIMITS somehow. not sure how I lost that.
I still don't understand everything yet and have to build some material tables.
What do the Ohmic Test, Z to top and Load sheet do?
  • phillc54
  • Platinum Member
  • Platinum Member
19 Apr 2019 06:30 #131218 by phillc54
Ohmic Test - John uses this to test for a shorted torch, it turns on the ohmic-enable output
Z To Top - moves Z to the top soft limit
Load Sheet - moves all axes to a place that is good for loading a sheet of material
All these are programmable in the ini file.
Cheers, Phill.
Time to create page: 0.444 seconds
