- Thank you received: 216
Another plasma component...
- islander261
7 years 6 months ago #131871
by islander261
Replied by islander261 on topic Another plasma component...
Phill
Does this code mean that both THC enable and using auto volts need to be true for IHS Skip to work?
I am just trying to plot a work around for my IHS Skip problem.
if(thc_enable && use_auto_volts){
axis_x_finish = axis_x_position;
axis_y_finish = axis_y_position;
}else{
axis_x_finish = 0;
axis_y_finish = 0;
- Thank you received: 4153
7 years 6 months ago #131881
John, thanks. Thats exactly what I worked out to do yesterday. Also yesterday Todd posted a G54 touch off routine that he uses to probe for the surface on his routers which was kind of perfect timing.
forum.linuxcnc.org/10-advanced-configura...-off-material-origin
The reason why I wanted to understand the gcode was it would be good to add some macro buttons to Gmocappy. One to touch off X & Y with one button press and maybe another other to touch off the Z axis as Todd has done. I know the Z axis one is not really necessary but we have a probe so we should use it. This would also be efficient from changing from say 16mm to 1.6mm material to keep the plasmac probe height pretty constant (if plasmac supports using offsets in that way.)
Call me lazy, but the default touch off requires a few button presses and it would be nice to do it in one! I don't know if you guys have used them but gmoccapy macros work quite well. In fact, I have one that parks the gantry that could make the load material button redundant.
Also I think BigJohn posted some example code to use the offsets optional R parameter to avoid the need to square the sheet. Just by jogging to the position of the sheet edge at each end. Maybe I can dig it up.
John, re your IHS skip, I take it you want to calculate it from the pierce position? I think somewhere, I have a seperate component that sets a pin true if a probe is required based on a distance from probe. You might just be able to and that with a plasmac pin somehow.
islander261 wrote: Rod
Here is my typical work flow as it may help clear things up. Using Gmoccapy in the Plasmac branch.
- Thank you received: 7491
7 years 6 months ago #131886
Replied by tommylight on topic Another plasma component...
That was along list of procedures !
Usually this is the workflow for my machines:
1 Turn power on
2 F1, F2, Home All
3 Open file
4 Press Play !
5 go grab a coffee and/or breakfast.
That is when there are no small parts to be cut, as that requires some attention to small parts peeking over the table in torches path.
Also using touch off sometimes, rarely.
1 Turn power on
2 F1, F2, Home All
3 Open file
4 Press Play !
- islander261
7 years 6 months ago #131893
by islander261
Rod
Yes, I have a number of macros I use with Gmoccapy, mostly for testing. I really find it very easy to use. The real world is most sheets are parallelogram shaped. I haven't tried JT's approach. When all is said and done I usually spend less than 2 minutes getting the work piece material square to the machine and origin offsets entered for 45 to 90 minutes of cutting.
- phillc54
- Thank you received: 2100
7 years 6 months ago - 7 years 6 months ago #131902
by phillc54
Guys,
I am away until Monday afternoon so I will only be able to answer questions, please keep them short as I [strike]don't like[/strike] hate typing on my phone which is the only device I will have with me.
Yes that is part of it, it also needs changes to the cut_offset calculation to do what you want:
I will work on this when I get back.
In the statistics do you want distance in inches or feet & inches?
Cheers, Phill.
if((axis_x_finish || axis_y_finish) && first_cut_finished){
cut_offset = sqrt(pow(axis_x_finish - axis_x_position, 2) + pow(axis_y_finish - axis_y_position, 2));
axis_x_finish = 0;
axis_y_finish = 0;
Cheers, Phill.
Last edit: 7 years 6 months ago by phillc54.
- islander261
7 years 6 months ago #131911
by islander261
Phill
Have well deserved weekend away! I'm glad that I'm not the only one that has trouble coping with all the small stuff on phones. I actually only turn mine on if I go to the mainland in case one of my old vehicles dies on the freeway( dual or more carriage way)!
I am aware of the need for changing the offset calculation if the reference point is changed. I just hadn't heard mention of the needing to be in auto volts mode before.
Machine work in imperial units traditionally uses inches as the measurement unit here. Feet and inches is usually reserved for the construction trades here and if you are racing horses furlongs get the nod.
Time to create page: 0.391 seconds
