Another plasma component...
7 years 5 months ago #132540 by bevins
Replied by bevins on topic Another plasma component...
rodw wrote:
bevins wrote:
rodw wrote: Hmm, why don't we just increase the number of tools to 257 like this and just do it all in the .mat file?
www.wiki.eusurplus.com/index.php?title=U...257_instead_of_56.29 ?
Why is this not done by default? 257 tools.
It is .... by Path Pilot.....
I checked the sources and it has not changed.,
Who do I have to send money to to get this done in the next release? lol
Think it would be possible to have this as a config option in the ini?
7 years 5 months ago #132542 by Dee436
Replied by Dee436 on topic Another plasma component...
Well, after a full rebuild using Stretch, and a fresh clone of Plasmac, plus the ini file changes that were pointed out, I now have a machine that will jog, home, react to soft limits and limit switches.
I wanted to check probing, but when I go into the plasma config tab or the plasma run tab I am unable to enter any setting, the spin buttons do not work and any numbers that I can type in manually just revert to 0 or blank when I move to the next box or try to save.
I also notice that the squares gcode file does not load at start up. I also still have to comment out the IHS skip or I get an error, see attached screenshot.
I feel as though I have a path wrong or some files missing. I have tried a new clone and copy of the files to my Plasmac directory but it was still the same. I also used to have a test window pop up that I no longer see.
7 years 5 months ago - 7 years 5 months ago #132556 by BigJohnT
Replied by BigJohnT on topic Another plasma component...
Rod, that's a good find... wonder why it's not done in master?
Someone needs to do a PR on that, I can't quite figure out how to start one, I know how to merge one lol.
JT
Last edit: 7 years 5 months ago by BigJohnT.
7 years 5 months ago #132566 by rodw
BigJohnT wrote:
rodw wrote: Someone needs to do a PR on that, I can't quite figure out how to start one, I know how to merge one lol.
JT
I was kinda hoping if Phill implemented it in his repository, it would find its way into master branch eventually!
7 years 5 months ago #132570 by BigJohnT
rodw wrote:
JT
Andy mentioned on the IRC that doing that is a huge increase in the NML memory, so I'm assuming that is the reason it has not be done. He also mentioned that he thought Rene was working on the tool table. And that a limit is silly because changing tools breaks blending anyway so motion only needs one tool... which would mean an unlimited amount of tools in the tool table. I wish my C and C++ was as good as my Python.
JT
7 years 5 months ago - 7 years 5 months ago #132575 by phillc54
John,
Thank you, what are the following?
Pause at end of cut=0.5
Wiggle length=9.999979999999999
DTHC delay -sec=1
NO DTHC - 0=1
Cheers, Phill.
Last edit: 7 years 5 months ago by phillc54.
Time to create page: 0.356 seconds
