- Thank you received: 2100
John, you win that bet.I bet Phill might like to finish his machine some day instead of chasing new features in Plasmac
Phill, I'm no expert on gcode but according to the docsphillc54 wrote: Rod,
I am using metric_tool_change.ngc in the nc_files directory.
If definitely has problems, seems like something to do with remapping, I must be doing it wrong.
You can see when you press run that the second tool loads, it actually does load the first one but goes straight through and loads the second.
Cheers, Phill.
rodw wrote: As you say this is not a milling machine, its a plasma machine.
I revisited your SQL wiki page recently to see if it could be incorporated into a plasma model and there was not one relevant data entity for plasma.
Which is why I have been speculating on whether replacing "task" makes sense.
linuxcnc.org/docs/2.7/html/config/ini-config.html#_task_section
The code is here:
github.com/LinuxCNC/linuxcnc/tree/master/src/emc/task
I don't know how much is relevant, redundant or reusable.
Well, one point of a database is that anyone can add their own dates items, and as long as the expected ones also exist, there is no problem. (whereas adding new items to the current tool table is a problem)
