plasma control panel
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
10 Feb 2021 21:44 #198327 by thefabricator03
Replied by thefabricator03 on topic plasma control panel
I gave up on the 320X drive but mostly because I could not find a quick solution to setting up the error and reset functions and I needed that in an industrial environment for safety.
Looking in my thread about setting them up and one guy seems to have worked it out using classic ladder. I will admit that is a pretty clever way around the problem. At the time I did not know enough about LinuxCNC to understand how that would work.
11 Feb 2021 07:02 #198358 by rodw
Replied by rodw on topic plasma control panel
I don't think I'd know enough either!
29 Mar 2021 17:41 #204078 by txtrone
Replied by txtrone on topic plasma control panel
I have just finished wiring my new closed loop stepper drives into my control box and added Rods hyper-sensing circuit.
I have attached a updated wiring diagram to this post for anyone that might find it useful.
What happened to the 220k resistor on the arcok? thx
30 Mar 2021 13:48 - 30 Mar 2021 13:48 #204123 by rodw
90-100 ohm, 10 W.
ArcOK is seperate to hypersensing and it seems not all machines need it. But maybe one day they will decide they do...
Last edit: 30 Mar 2021 13:48 by rodw.
30 Mar 2021 13:53 #204124 by txtrone
90-100 ohm, 10 W.
So, Fabricator's final schematic is missing the ArcOk resistor?
30 Mar 2021 13:59 #204128 by rodw
I'm not sure many do add it as its a fairly recent learning. I think his build predated that point.
30 Mar 2021 14:09 #204129 by txtrone
In this thread, post #134766, he had a 220 ohm in the schematic. By post #148670 there was no resistor. That was the one I was asking about... just to make sure we are talking about the same thing.
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
30 Mar 2021 22:16 #204154 by phillc54
Replied by phillc54 on topic plasma control panel
I think a better idea is to do as PCW suggests and use a 1uf capacitor.
forum.linuxcnc.org/plasmac/40819-arc-ok-...fire?start=50#191678
The following user(s) said Thank You: txtrone
31 Mar 2021 18:10 - 31 Mar 2021 18:20 #204253 by txtrone
I read what PCW had to say... it's a little bit above my pay grade. Is he (I assume it's a he) saying that the 1uf cap would prevent the problem that the OP (and others) were trying to correct with resistors? ... I believe it was the buildup of some sort space dust in the flux capacitor they were trying to blow off.
Last edit: 31 Mar 2021 18:20 by txtrone. Reason: Clarification
31 Mar 2021 21:58 #204318 by rodw
Did someone mention a dusty spaceship?
Yes, if a relay is switching a low current, space dust or oxide can build up on the relay contacts which can result in intermittent/failed operation. The relay manufacturer's specify a minimum current that is sufficient to "burn" off the oxide so it does not form.
Time to create page: 0.502 seconds
