Configuring Plasmac - a complete THC/plasma config for any hardware
7 years 3 months ago #140380 by EW_CNC
I just got my plasma table changed over to PlasmaC on Debian Stretch. Thanks for all the efforts in this! Yesterday I did a successful cut with it. Now today I had trouble with the touchoff. It would come down (ohmic probe) touch steel and trigger ohmic probe, but continue down till I got error " bottom limit reached while probing down. Then when I shut down Linuxcnc I get the following error.
File Name: Report.txt
File Size:8.16 KB
Last night I tried adding my custom PYVCP panel to axis (probably not a good choice because it didn't work). Does this have anything to do with my problem? What is the best way to add my own custom buttons to Plasmac?
7 years 3 months ago #140381 by phillc54
Can you post your ini file?
How many extra buttons do you need?
7 years 3 months ago #140382 by EW_CNC
I need four extra buttons, I have my downdraft table divided into 4 sections. I need them to control the zone valves. Sometime I would like to have it control them automatically with the location of the cutting torch. I attached my ini and also a second error report. Thanks, EW
File Name: imperial_plasmac.ini
File Size:10.81 KB
File Name: Report_02.txt
File Size:8.42 KB
7 years 3 months ago #140383 by rodw
Like this?
This is actually using custom component that divides the table into 2 zones, but you can use the Lincurve component to create the zones along the Y axis position and trigger a switch accordingly.
The following user(s) said Thank You: EW_CNC
7 years 3 months ago #140384 by phillc54
A quick test seems to show that you cannot mix GladeVCP and PyVCP in Axis, that would probably be the reason for your errors.
You could create a GladeVCP panel for Axis but you wouldn't be able to use Axis with the run panel on the right hand side, you would have to have the run panel as a tab behind the preview.
The other option would be Gmoccapy with a GladeVCP panel on the right hand side.
Gmoccapy also has the option of Macros
I didn't see a reference to a PyVCP panel in your ini file
7 years 3 months ago - 7 years 3 months ago #140388 by phillc54
I just noticed in your ini file that you have:
HALFILE = ./imperial_plasmac_cmds.hal
That file is normally created by LIB:basic_sim.tcl to show what HAL commands were created for the sim config.
It should be commented out in a working config.
Last edit: 7 years 3 months ago by phillc54.
Time to create page: 0.391 seconds
