- Thank you received: 33
I removed the PyVCP from the INI and still get the errors.I didn't see a reference to a PyVCP panel in your ini file
I have my hal commands spread between that file and my original hal file. Should I combine it to one single hal file?I just noticed in your ini file that you have:
HALFILE = ./imperial_plasmac_cmds.hal
Looks Good.This is actually using custom component that divides the table into 2 zones, but you can use the Lincurve component to create the zones along the Y axis position and trigger a switch accordingly.
It seems you didn't use the configurator to create your config, you have multiple commands doing the same thing.I didn't see a reference to a PyVCP panel in your ini file
Do I have all the commands I need, or which commands don't I need with Plasmac? Do I need the PID Commands on all the axis with a stepper system?
I would recommend that you create a new base machine . In your case you would use Stepconf
Then make sure everything works correctly.
When you have a working base machine then use configurator to get PlasmaC working
