- Thank you received: 312
Tumbler Build - For cleaning plasma cut parts.
- thefabricator03
- Visitor
machinedude wrote: i think the shop i work at paid somewhere in the ball park of 450 k for the machine they bought. i completely agree with that kind of cash you could fund quite a few builds of you own and cover just about any process you can think of for that matter.
I have a major problem living on a continent at the bottom of the world. Our currency is crap and just about all machine are imported.
I am toying up building my own VMC next year when I get my robots finished. I am sure I will annoy the crap out of you with questions about VMC's since I have never used one. I am thinking epoxy frame like you filled your Plasma frame with. If I build one I can make it much bigger than anything I can afford to import as the larger machines are in the $100K AUD range. Building one with DMM servos and a large tool changer would come in around $20k AUD, and of course will be fully open source!
- thefabricator03
- Visitor
www.cnczone.com/forums/vertical-mill-lat...cnc-forum-posts.html
Some great stuff there!
- thefabricator03
- Visitor
- machinedude
if you want to do E. G. i would suggest making the frame from some big tubing and then filling the tubes with the E.G. that way you get the vibration dampening for any cutting you do. E.G. has done wonders for what i have done just avoid the way i did it. to much work in making it look nice. filled tubes would be the way i would go doing it over again cut cut some fill points in the tubes and be generous with the size because this material does not flow well at all so wide open space is your friend in your design process.
- Thank you received: 7491
I was thinking of doing the same thing, but not with sand, sand is to light.machinedude wrote: if you want to do E. G. i would suggest making the frame from some big tubing and then filling the tubes with the E.G.
Since you have a plasma cutter, use the dross left on the table, it is fine metal powder and it is 3 times heavier than sand. Wash, dry, mix, fill. Have not tried it yet, so i do not know how that would end up, but it sure seems like a good idea in my head.
- thefabricator03
- Visitor
I can attest to how heavy it is. Much heavier than sand.
