Tumbler Build - For cleaning plasma cut parts.
  • thefabricator03
  • Visitor
  • Visitor
6 years 2 months ago - 6 years 2 months ago #177678 by thefabricator03
Replied by thefabricator03 on topic Tumbler Build - For cleaning plasma cut parts.
Outside all sheeted except the doors and roof,
Last edit: 6 years 2 months ago by thefabricator03.
6 years 2 months ago #177679 by machinedude
Replied by machinedude on topic Tumbler Build - For cleaning plasma cut parts.
if your intention was leaving the tube tube open in the front for a place to get forks in to move it around that was pretty smart :) but your shop is big enough to move a fork truck around in pretty easy.
i would be in heaven if i had that much space at home and had the stuff to move the big stuff around quickly and easily :)
very nice work.
  • thefabricator03
  • Visitor
  • Visitor
6 years 2 months ago #177680 by thefabricator03
Thanks,
Yeah they are pockets for the forklift tines to move it around when needed. The shops pretty big but on the weekdays we pack it full of steel with seven guys working in side, I move out the big stuff on Friday arvo's to make way for my weekend projects.
6 years 2 months ago #177681 by machinedude
i keep watching the news to see if we are going to get some of our tax money back in a stimulus check. i have my eyes on a cheap hobby TIG in my price range. my hopes would be to things more normal when it comes to frame building in the future.
small unit but is AC/DC so welding everything would be on the table up to 3/16 thick. so a frame for the little lathe i have is in the plans along with a complete over haul of the thing.
so since i am not a welder i might be bugging you for tips and tricks :)
once the gantry mill is done that will open up a lot of potential in my methods :)
  • thefabricator03
  • Visitor
  • Visitor
6 years 1 month ago - 6 years 1 month ago #180899 by thefabricator03
Progress has been slow with the tumbler, I have had the last couple weeks off with the birth of my second son. I hope to get everything apart from the electronics finished in the next couple of weeks,
Center wall, VFD and control box supports tacked in,
The bearings that support the barrel shaft are wider at the top than at the base. I had to offset the internal wall to allow the wall sheet to miss the bearings. If I were to do it again I would just cut a wider notch in the wall sheet to go around the bearing offset and leave the wall flush with the drum frame.
Last edit: 6 years 1 month ago by thefabricator03.
6 years 1 month ago #180945 by machinedude
it's tough making head way on projects when life gets involved :) the last two months have been that way for myself. i know when my oldest daughter has her baby things are going to get even more side tracked :)
congratulations on the new baby boy :) first few months are tough but gets better as you know already. pretty sure i will be in the same boat since my daughter still lives with me :)
congratulations regardless :)
Time to create page: 2.113 seconds
