Tumbler Build - For cleaning plasma cut parts.
  • thefabricator03
  • Visitor
  • Visitor
5 years 11 months ago - 5 years 11 months ago #189936 by thefabricator03
Replied by thefabricator03 on topic Tumbler Build - For cleaning plasma cut parts.
Now to get this thread back on topic from myself,
Have I been doing little bits and pieces on the tumbler of the last couple of months,
Center wall sheeted,
VFD and control box mounted,
Even though its only half finished it has been doing a lot of work. I use it every other day.
Last edit: 5 years 11 months ago by thefabricator03.
5 years 11 months ago #189947 by rodw
thefabricator03 wrote: None of our three phase machines use a neutral.
I'm still learning about this 3 phase thing but based on the wiring I've done, the 4 pin is for a 10 amp circuit and the 5 pin is a 32 amp circuit.
  • thefabricator03
  • Visitor
  • Visitor
5 years 11 months ago - 5 years 11 months ago #189948 by thefabricator03
Not sure about that, my 125 amp plasma is very much a 32amp drawing machine and it only uses 4 pins.
From what I have learnt is that L1,L2,L3 are the three phases and the bottom 4th pin is the earth. I have been told that the middle 5th pin is the neutral.
It would be interesting to know how they wiring single phase with three phase wiring. I would assume they would just use one of the phases and the earth and neutral but not sure. With the three phases on 415 they are 138.3 degrees out of phase, so I wonder how that works with single phase.
5 years 11 months ago #189949 by johnmc1
With the 5 pin regardless of amperage
L1 > ( any two active lines ) > load L2, voltage = 415 volts
L1> load >(middle pin)neutral , voltage =240 Volts
Earth remains the same
The following user(s) said Thank You: thefabricator03, Coachbuilder
  • thefabricator03
  • Visitor
  • Visitor
5 years 11 months ago #189950 by thefabricator03
So when motors run backwards, its because L1 and L2 are around the wrong way?
And L3 is just another active line?
5 years 11 months ago #189951 by phillc54
Replied by phillc54 on topic Tumbler Build - For cleaning plasma cut parts.
You can swap any two phases.
Time to create page: 2.223 seconds
