- Thank you received: 21
Tumbler Build - For cleaning plasma cut parts.
- johnmc1
5 years 11 months ago #189953
by johnmc1
Replied by johnmc1 on topic Tumbler Build - For cleaning plasma cut parts.
Direction for a single phase motor is controlled by the capacitor connection to the motor,s start run winding,s .
Three phase motor direction, is controlled by how the phases are connected .
eg L1 -L2-L3 =cw then L1-L3-L2 - ccw
- Thank you received: 4153
5 years 11 months ago #189954
Replied by rodw on topic Tumbler Build - For cleaning plasma cut parts.
Yeh sounds right. If you don't want single phase power, there is not really any reason to run the neutral.
In the switch board, they try to balance your single phase circuits across the three phases.
There isn't any standard for wiring of the phases apparently where a motor is involved, you may need to swap any two phases to go the right way. But if its say a welder that only uses DC motors its not an issue.. Worked for my welder.
- thefabricator03
- Visitor
5 years 11 months ago #190083
by thefabricator03
Replied by thefabricator03 on topic Tumbler Build - For cleaning plasma cut parts.
Turns out that with three phase the different power point styles are related to the amperage draw of the machines that will be used.
The style of power point that the guys installed was to suit up to 20amps. The plug I put on the compressor was a 32amp plug. Just need to change the plug over.
- Thank you received: 7491
5 years 11 months ago #190120
Replied by tommylight on topic Tumbler Build - For cleaning plasma cut parts.
When i watch you discussing a power plug for 3 days, i feel sorry for you !
In Europe, you can spot what plug it is from a mile away, the only similar ones are industrial plugs for 16A and 32A and even they can be differentiated from very far by the size of it.
Done gloating, off to work, building a work shop about 108 sq meters with a friend helping, building two more plasma cutters same as last two i did, building the one for square tubing and while collecting parts for it found out i can do another one for round tube ...... oh hell !
- thefabricator03
- Visitor
5 years 11 months ago #190144
by thefabricator03
But Tom, we are having so much fun!
Left is 20amp, Right is 32amp.
5 years 11 months ago #190145
That reminds me, remember those bloody keychains that would beep when you whistle at them ?
Get some of those and set different types of beeps for different plugs, otherwise i foresee a lot of failed attempts at plugging ....
All jokes aside, the industrial ones here all look the same ( the colour can be different ) but the size difference is much more noticeable.
Time to create page: 2.524 seconds
