My Newb Plasma Table Attempted Build
- dvn4life1972
- Thank you received: 173
14 Aug 2020 23:37 #178232
by dvn4life1972
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
Then hopefully yours wasn't empty like mine is
- Thank you received: 7506
15 Aug 2020 02:51 #178241
Replied by tommylight on topic My Newb Plasma Table Attempted Build
Car gearbox oil while testing, then same as Rod.What're you guys using for lube (grease) on your bearing blocks?
The following user(s) said Thank You: rodw, dvn4life1972
- machinedude
- Thank you received: 312
15 Aug 2020 06:15 #178257
by machinedude
Replied by machinedude on topic My Newb Plasma Table Attempted Build
i used this Brand just because it was easy enough to get. Advanced auto parts stocks it and it was around 5 or 6 bucks for a tube. i seen it works for high speed bearing applications so seemed like a good fit. i'm not sure what kind of auto part stores are in your area but i would think any store would have some choices.
The following user(s) said Thank You: dvn4life1972
- dvn4life1972
15 Aug 2020 09:08 #178280
by dvn4life1972
I'm in Texas, so we have Advanced stores around.
- dvn4life1972
15 Aug 2020 09:09 #178281
by dvn4life1972
I used silicone spray while testing...I'll grab some grease today for it.
- dvn4life1972
20 Sep 2020 08:28 #182899
by dvn4life1972
Rod,
Aren't you running one of the Gigabyte BRIX PC's? If so, which one? I've had a heck of a time getting my latency down to 200000 on it. Getting back to the 4.9.x kernel reduced it by half, but I can't fine-tune things in BIOS because mine is UEFI.
Found that the latency is pretty horrible on the Gigabyte BRIX S PC that I got for the table. I just swapped it back to the older Dell desktop
Define pretty horrible please!
Remember that you are not running a base thread so latency requirements are much relaxed. Maybe < 200000 is still OK. Also the included wifi is awful so pull it and add a USB wifi dongle.
Rod,
- dvn4life1972
20 Sep 2020 15:27 #182953
by dvn4life1972
I've circled back and succeeded with making this BRIX PC work to control the machine. This is a good score for me because now I can easily fit all of my electronics into the new enclosure I had bought for the table retrofit.
Also, I now have my THCAD-5 so I can soon get on with the hypersensing. Just need to get the ohmic part for the wire to hook onto. That would make this a proper half-pint table then, wouldn't it?
20 Sep 2020 16:02 #182961
Glad you got it working.I've circled back and succeeded with making this BRIX PC work to control the machine.
- Thank you received: 4155
20 Sep 2020 16:10 #182965
Me too!
I never had any problems getting the BRIX to an OK latency. It makes me think that they must have changed something as I bought mine a few years ago.
Replied by rodw on topic My Newb Plasma Table Attempted Build
Me too!
- dvn4life1972
20 Sep 2020 16:31 #182969
by dvn4life1972
Rod, I think the major change that is causing the hiccups is they ditched regular BIOS for straight-up UEFI. Had to depart from my old-school but familiar Debian Stretch, as there's no way to boot into it to get it installed on these now. Mint is nice though, definitely more modern lol.
Time to create page: 0.348 seconds
