- Thank you received: 9
rodw wrote:
xnaron wrote: @RodW I know we had talked about the 25K 5Watt resistor needed for the ohmic thcad-5 setup. Does it replace the 300K resistor below?
No Its in addition to it on the high voltage side as a pull down or pullup. I'll check it out when I get a chance and advise.
Thanks. My eyes read the diagram wrong on the plasma primer. It is 390K not 300K
I am wiring up my controller this weekend.
xnaron wrote: Do you know what my THCAD divider setting should be?
