- Thank you received: 9
xnaron wrote: Excellent! Thank you @snowgoer540.
So 1/32 for the ohmic thcad-5 setting. Is it the same for the THCAD-5 that is connected to the 50:1 on the hypertherm?
F/32 can be used with parallel port, but requires RTAI kernel and a lot of fiddling, i have a system running like that for 7 months without any issues.snowgoer540 wrote:
xnaron wrote: Do you know what my THCAD divider setting should be?
F/32 is what is recommended, unless you are using a parallel port (which I dont think you are).
