Controller build for Plasma
6 years 2 months ago #179570 by xnaron
Replied by xnaron on topic Controller build for Plasma
Hmmm...
I can't say that I am happy about the proximity of the 24V supply to the top of the stepper drivers when the door closes. It is about 2cm away at most. I guess if I run into any weird issues I can open the door to eliminate the power supply as an issue. It is a mean well power supply so hopefully not as noisy as some other off brands. I could also add a tin shield.
6 years 2 months ago #179587 by xnaron
THCAD-5 Unipolar or Bipolar on jumper (ohmic and thc). They came set to unipolar.
6 years 2 months ago #179591 by tommylight
The following user(s) said Thank You: xnaron
6 years 2 months ago #179598 by xnaron
Ok powered it up and no smoke! I can move on to the software side now.
I have linux mint 19.3 installed and a buildbot version of 2.9. I just installed ohmic3.comp. I haven't connected to the 7i96 yet or started configuring my machine. I followed Rod's pdf on connecting things on the controller. I don't have everything that Rod has on his machine but I do have all the important stuff. Rod said I needed to flash my 7i96 to get things working for the hypersensing. I am installing the 7i96 tool and will need to know where to download the file to flash the 7i96.
6 years 2 months ago #179601 by snowgoer540
xnaron wrote: Ok powered it up and no smoke! I can move on to the software side now.
Before you get too far down the rabbit hole, you should know that 2.8 is the official "developed for" version of Linuxcnc as far as Plasmac is concerned. You'll notice the Plasmac User guide is void of how to get to 2.9 (although I see there is one accidental reference to "master").
Find the firmware here: store.mesanet.com/index.php?route=produc...oduct&product_id=311 Click Specification, then support software in the zip file theres a 7i96pl.bit. That's the one you want to flash to the mesa board.
6 years 2 months ago #179610 by xnaron
snowgoer540 wrote: Before you get too far down the rabbit hole, you should know that 2.8 is the official "developed for" version of Linuxcnc as far as Plasmac is concerned. You'll notice the Plasmac User guide is void of how to get to 2.9 (although I see there is one accidental reference to "master").
Ok thank you. I just want to go with what works well. I will switch to 2.8. Thanks for the link to the firmware.
Time to create page: 0.151 seconds
