- Thank you received: 17
Post Processor for LinuxCNC and PlasmaC
- jay1st
rodw wrote: So lets say you design a cool single piece bumper for your jeep in Solidworks and its time to cut 20 flat patterns out of sheet metal ready to be folded up on a brake press. You save your part as a DXF file and load it in Sheetcam. You choose the material and then you nest your 20 parts on a single sheet of steel.
Then you run the post processor in Sheetcam and that converts your file in to gcode based on the rules in a text file that is part of sheetcam (your POST) You set your CNC plasma cutter up for that job, load the gcode file into plasmac and press the start button. The generated gcode loads the appropriate plasmac material to set the cutting parameters.
So that is the CAD/CAM workflow.
I thought the "tools" were listed in sheet cam ?
By tools i mean material thickness and power settings from the plasa cutter ?
- Thank you received: 4153
Sounds a bit backwards but it works well.
- jay1st
The processor bit confused me and i got side tracked
- JTknives
- Thank you received: 32
JTknives wrote: So I have been out of the loop for a good bit. I’m getting ready to send my table information to hypertherm so thy can create the machine profile for me to run in pronest. Thy wanted me to use my current post processor to process their file. In doing so I noticed that sheetcam now has a post processor built in. Has anyone used this and if so how well does it work. I noticed it’s output is a bit different then what I’m currently getting from my tried and true post processor. Then again I’m running a really old version of plasmaC from almost a year ago.
Can you let your Hypertherm contact know I asked their Australian Distributor (TrueCut) to ask them to build a post processor on behalf of the LinuxCNC community? I was told the request was passed on. Happy to help.
Can you post the two post processors? I know Les agreed to add a plasmac processor and he is involved with Linuxcnc so maybe he did add one. Also I think Phill has included one in later versions of Plasmac so I think output from that is the one to use as a model.
- JTknives
