Post Processor for LinuxCNC and PlasmaC
7 years 5 months ago #133712 by phillc54
Replied by phillc54 on topic Post Processor for LinuxCNC and PlasmaC
Rod,
One thing you need to remember is that the F word MUST be after the M66 line so that it reads the feed rate from the correct material.
Cheers, Phill.
7 years 5 months ago #133714 by rodw
Replied by rodw on topic Post Processor for LinuxCNC and PlasmaC
phillc54 wrote: Rod,
Cheers, Phill.
Phil, yes, thats all fixed now. The guys seemed to be impatient so I did your trick and did about 47 new versions in 24 hours.
For the followers, I have uploaded a new version on another thread. This zip file includes the post processor, a sample dxf file and the generated output from Sheetcam where I made a seperate layer for the holes and used a Sheetcam tool with a special name "CenterPunch" to mark the hole centres. Its only a small file so even guys with the free version of sheetcam should be able to play with this.
You can download it from here.
forum.linuxcnc.org/media/kunena/attachme...0/Postsamples.tar.gz
The following user(s) said Thank You: Franklin
7 years 4 months ago #135651 by JTknives
Replied by JTknives on topic Post Processor for LinuxCNC and PlasmaC
How are you setting X0 and Y0 on your machine. I did not see any call outs for offsetting from the machine zero/home position.
7 years 4 months ago #135655 by rodw
JTknives wrote: How are you setting X0 and Y0 on your machine. I did not see any call outs for offsetting from the machine zero/home position.
We are using the default Gmoccappy touchoff buttons for X & Y touchoffs. There are blueish buttons for each axis.
7 years 4 months ago #135663 by JTknives
Oh ok. So you are using G54 you just don't need to call it out because its already been called out when linixcnc launches. I had been using g10p20 to set the g54 to my current position.
  • thefabricator03
  • Visitor
  • Visitor
7 years 4 months ago #135896 by thefabricator03
Replied by thefabricator03 on topic Post Processor for LinuxCNC and PlasmaC
Has anyone else had a problem getting the gcode program to load in the preview window?
I have tried the program Rod posted earlier in this thread, I have also tried a program I created with Sheetcam using Rods post processor,
Do I need to have the HAL and INI files set up first before it will show?
I would of thought I could of got it to load using the sims.
Time to create page: 0.142 seconds
