- Thank you received: 2100
RS485 For Hypertherms
- thefabricator03
- Visitor
snowgoer540 wrote:
This looks good, and is very helpful! It may be prudent to show how the 5 pins on the terminal block shown correspond to the actual DB9 connector in the event that the 5 pin terminal block connector isnt available. I can only find 9 pin terminal block versions on Amazon. Although I believe your chart does have enough description to get you there.
Just a thought! Thanks again.
Just something I thought of. I am not sure if all of the RS232 cards have the same DB9 pins for the same signals. Maybe if someone can confirm that is a standard, I will map my DB9 connector and post the pinout. I just dont have a lot of time to research that at the moment.
- phillc54
Edit: Does this relate to yours opengear.zendesk.com/hc/en-us/articles/2...-DB-connector-pinout
- thefabricator03
- Visitor
phillc54 wrote: The RS232 pins are standard although whether the pins for adapters are standard I have no idea.
Ok I will map the my connector pins tomorrow and modify the reference doc. I will just make a note that it is specifically for that connector.
- phillc54
I don't think it is worth worrying about, so long as the pin function is known is should be no problem.
- thefabricator03
- Visitor
phillc54 wrote: Did you see the link in the previous post.
Ok, yeah I think the main thing is knowing the pinout on the plasma unit and if you create your own DB9 plug you would just need to map the correct signals together. The reference doc does show the mapping so most people should be able to figure it out.
- phillc54
