- Thank you received: 7491
RS485 For Hypertherms
Will check promptly if i have any left, and will do a giveaway if anyone needs them.
- alexandrub
- Thank you received: 5
- thefabricator03
- Visitor
alexandrub wrote: I made the comunication with an usb to rs485 from Icp-con 7561. It is working but i want to verify something. In material table i define a material with 45a and 128v. I start the process , everything if fine but in the voltage field in Plasmac i see only 60v. How can i verify where is the problem? I let the voltage divider on Powermax at 1:20, i made some test with a adjustable power source on the thc and seems to be fine...in this case if the voltage is not real in Plasmac, the thc is not working in real condition i think.
RS485 does not control voltage, only amperage, air pressure and error code display.
Have you got voltage sampling turned on? If so the displayed voltage is irrelevent as the voltage at the start of the cut will determine the voltage for the cut path.
Check out the Plasma Primer for more info on voltage sampling, linuxcnc.org/docs/devel/html/plasma/plas...rch_voltage_sampling
- Thank you received: 4153
Can you advise your THCAD Model (-5, -10, -300)
The calibration data on the sticker on your THCAD
The value of any scaling resistor you have added
\provide a screen dump of your cut settngs that show the scaling data you have used in Plasmac
If your plasma supports it, I wold recommend a 30:1 divider setting, no scaling resistor and a THCAD-10. This will give a 300 volt full scale.
- alexandrub
Ok. And how can i adjust the voltage
I see in the cutting chart that the voltage need to be adjusted. As an example at 45A and 128v at 5560 i will cut 2mm thicknes steel and at 45A but 136V at 780mm/min i will cut 10mm thicknes steel.
About voltage sampling i need to see tommorow in the shop.
Thank you for answer.
- alexandrub
rodw wrote: It can be your scaling resistor or your config settings.
Thcad is -10
sticker attach picture
I dont have any resistor attached
I attach a picture with scaling data
If I need I will change the Powermax divider to 1:30
