Problem loading PlasmaC for the first time
04 Oct 2019 16:25 - 04 Oct 2019 21:39 #147121 by Clive S
I am have a bit of trouble loading linuxcnc.
If I comment the line out in connections.hal net plasmac:arc-voltage-in hm2_7i96.encoder.00.input-a => plasmac.arc-voltage-in
It will load and I can home the machine.
Am I using the correct pin ? I will try this in the morning hm2_7i96.0.encoder.00.velocity
Last edit: 04 Oct 2019 21:39 by Clive S. Reason: added text
04 Oct 2019 22:49 #147146 by phillc54
Replied by phillc54 on topic Problem loading PlasmaC for the first time
yes, velocity is the one you need.
05 Oct 2019 08:15 #147162 by Clive S
Replied by Clive S on topic Problem loading PlasmaC for the first time
Thanks Phill . That did the trick, now with the machine idle I see a very small fluctuation in the arc voltage close to zero (not calibrated yet so would expect this)
Q1. re the breakaway switch: With the torch in position the monitor shows RED (should the switch be NC or NO with the torch in position?)
Q2. Should the probe test button start the probing. I have not been able to get it to start the probe.
Thanks.
05 Oct 2019 08:47 - 05 Oct 2019 08:49 #147164 by phillc54
The indicator should be off when the torch is in position. I use a NC and use the inverted input (in-not).Actually I don't have a breakaway, I use the Float as a breakaway as well...
You need the machine homed for a probe test.
Last edit: 05 Oct 2019 08:49 by phillc54.
05 Oct 2019 09:19 #147168 by Clive S
Yes I had the machine homed but did not get any response from the "probe test"
05 Oct 2019 09:32 #147171 by phillc54
Check in the .ini file that the button code for the appropriate button is something like:
probe-test 10
Or post your .ini file.
05 Oct 2019 11:09 #147184 by Clive S
probe-test 10
Breakaway switch sorted by inverting the pin by adding "_not" to it.
Probe test problem. I change the speed from 1 to 50 in the plasma config panel abd checked ini file for probe-test 10
Also on pressing "Z to top" button it errors "see screen shot"
I notice that the "Ohmic test button" randomly flashes in time with the arc voltage notification.
File Name: plasma_mac...ions.hal
File Size:2 KB
File Name: plasma_machine.ini
File Size:9 KB
File Name: plasma_machine.hal
File Size:7 KB
05 Oct 2019 11:27 - 05 Oct 2019 11:31 #147185 by phillc54
Try changing the -0.0401 in the BUTTON_3_CODE line to -1.0 for the Z limit problem.
I see you are not using ohmic probing so you could reprogram that button to something else.
I am not sure what the random flashes would be.
Edit: Probing at 1mm per minute is very slow.
Last edit: 05 Oct 2019 11:31 by phillc54.
05 Oct 2019 11:37 #147186 by Clive S
Yes I only have a scratch start
Probe test problem. I changed the speed from 1 to 50 in the plasma config panel and checked ini file for probe-test 10
To be clear probe is not working yet
The Z limit problem is only there when pressing Z to top button
Thanks for the help.
05 Oct 2019 11:51 #147188 by phillc54
So, when you press Probe Test nothing happens?
Time to create page: 0.309 seconds
