Problem loading PlasmaC for the first time
- Thank you received: 7485
the torch on signal should be given together with probe sequence so the plasma has time to turn on before the metal is reached,
or
the torch on signal should be initiated as soon as the float switch it tripped.
Both of those situations means: no ohmic probing for you !
- phillc54
- Thank you received: 2100
PlasmaC doesn't fire the torch until Pierce Height is reached so you will need to set enough time in Arc Fail Timeout in the Config Panel to allow the torch to fire.
It should also start on contact loss, so having the torch on signal routed to one of the above should do, most probably the second of the two versions mentioned.
- phillc54
There is something else I don't know about and have made no allowance for.His torch will not fire until it is dragged over the metal plate being cut, he has a scratch start plasma.
So with a scratch start we need to turn the torch on when the float switch makes contact.
Ohmic would be a problem though as we don't disable the ohmic sense circuit until the torch has lost contact with the material???
Scratch start is tricky and it usually needs several scratches to start, but since the situation is such, i was thinking of ways it could most probably work.
Yes, and that is contingent on the plasma actually starting without any delay. Any delay and the torch would have already started to retract and lost contact.So with a scratch start we need to turn the torch on when the float switch makes contact.
@Phill
This is an isolated case, no changes need to be made to PlasmaC code for this, just adding an OR gate to hal should do that.
The main thing is, scratch start plasma is not made for use in CNC applications. Then again if it does work, we got some more functionality.
- phillc54
Oops, I see that now...I did write two posts above that no ohmic can be used for this situation
That is good news, this shows up my lack of knowledge about plasma.This is an isolated case, no changes need to be made to PlasmaC code for this, just adding an OR gate to hal should do that.
I was thinking of adding an ini file setting for scratch start and starting the torch earlier but if the OR gate works then I can just add something into the docs.
- Clive S
- Thank you received: 486
Q1. Is it possible to modify the plasma?
Q2. Should I buy another machine if so what is the terminology for me to use ie. scratch start, HF start, etc.
Is this the same as scratch start www.ebay.co.uk/itm/R-Tech-P30C-240V-12mm...3:g:64QAAOSwk~Vdm73Q
or this www.expondo.co.uk/stamos-power-2-plasma-...-50-a-230-v-10020153
- thefabricator03
- Visitor
Edit: Ideally with a CNC port for machine control.
No worries, we will try to find a way to make it work, and we do need your feedback as i do not have a scratch start plasma to test and most probably neither of other forum members with machines.
@Phill,
Thinking about it, OR is not needed, just omitting an existing line and adding another one, namely, omitting the line that activates the torch and wiring it to the switch in HAL.
@TheFabricator,
That is a good advice as they tend to cause less interferences and subsequently less issues with shielding and cable routing.
