Problem loading PlasmaC for the first time
05 Oct 2019 11:54 #147189 by phillc54
Replied by phillc54 on topic Problem loading PlasmaC for the first time
So, when you press Probe Test nothing happens?
Edit: Your Probe Height and Safe Height are very low.
05 Oct 2019 14:04 - 05 Oct 2019 14:05 #147197 by Clive S
Replied by Clive S on topic Problem loading PlasmaC for the first time
I have tried the safe height at 60 and probe height to 30 I notice these are +ve numbers my Z is -ve going down
Phill I have noticed that when I change the settings in the config panel for probe speed etc it does not save them on the next load.
Disclosure: I have moved files from the machine to a usb stick and back would this affect file permissions?
Last edit: 05 Oct 2019 14:05 by Clive S.
05 Oct 2019 21:11 #147221 by phillc54
Safe height is relative to the top of the material, probe height is relative to the bottom limit.
Did you click on Save?
If it were a permissions problem then I would imagine you would get error messages in the terminal window.
Are you running LinuxCNC from a terminal?
05 Oct 2019 23:09 #147226 by Clive S
Yes
05 Oct 2019 23:21 #147227 by phillc54
I also use a 7i96 so Iif you can zip your config directory and post it I can try to adapt it tomy machine sometime tomorrow.
06 Oct 2019 07:43 #147239 by Clive S
That's very kind of you Phill. Beyond the call of duty Thanks
I have just noticed that there is no metric_parameter.txt file in there. Rod has my email if you need it.
File Name: plasma_machine.zip
File Size:308 KB
06 Oct 2019 21:40 #147291 by tommylight
Replied by tommylight on topic Problem loading PlasmaC for the first time
Checked it today and probe works as it should. Well everything works, besides some minor issues at first start.
Also checked the voltage tracking and it works perfectly. Need to finish a machine, quick. I was testing with electronics on the table, simulating float switch with a piece of wire and simulating THCAD with a DC servo motor wired to an adjustable power supply and the encoder used for feedback to 7i92 encoder input.
07 Oct 2019 01:19 - 07 Oct 2019 01:46 #147304 by phillc54
Clive,
Is your machine imperial or metric, there are a couple of conflicting .ini file entries.
Edit: After you home the machine are the DRO readings correct (Y5 Z0) or are they Y5 Z5?
Last edit: 07 Oct 2019 01:46 by phillc54.
07 Oct 2019 03:49 #147307 by phillc54
Clive,
Forget my previous post it seems you are using metric in which case you need to edit the [RS274NGC] and change imperial to metric in the two appropriate lines. Then fix any parameters as below if needed.
Clive & Tom,
The non saving issue may be that if you change a value by keyboard then you need to either press 'Enter' or click on the up/down arrow in the spinbutton to make it stick. That is either a GTK or GladeVCP behaviour that I cannot (or don't know how to) change.
I should put a not in the PlasmaC docs about that.
The following user(s) said Thank You: tommylight, Clive S
07 Oct 2019 06:55 #147311 by Clive S
Clive,
I will check this out and report back
Clive & Tom,
I have seen that behaviour before. Yes it would be good to put it in the docs.
Phil Thanks for taking the time helping me with this it is appreciated :)
Time to create page: 0.321 seconds
