Fusion 360 post processor file for Plamac
2 years 4 months ago #303856 by RMJ fabrication
I am now running into this error again with every new gcode file I make and I didn't change anything. All the Gcode files look exactly the same as the one that works coming out of fusion. Qtplasmac keeps adding M02 (end program) to the first line of my gcode files. please can anyone help, what number does the material number need to match in order to stop qtplasmac from doing this?
2 years 4 months ago #303859 by phillc54
Check that all material numbers called in the G-code file do exist in the QtPlasmaC materials.
linuxcnc.org/docs/devel/html/plasma/qtpl...ic_material_handling
The following user(s) said Thank You: RMJ fabrication
2 years 4 months ago #303860 by RMJ fabrication
Ok I got it now thank you so much sir. I created a new material with the material number one thats all I was missing.
2 years 1 month ago #311085 by Sparkman61
Is anyone is actively developing Fusion 360 post processor?  I ran into an issue that someone should document if it isn't documented somewhere already.
I noticed that there MUST be a lead-in defined in Fusion 360 or the torch won't fire (M3 command won't be generated) with open chain geometry.  This might also be true for closed chain geometry - didn't have time to look at that.  I was working on some art work that didn't have closed chain geometry and couldn't figure out for the life of me why the M3 command wasn't being generated.  Took a bit of experimenting to figure out how the settings worked, or, in this case didn't.
I've been resistant to give SheetCam a try a) because Fusion 360 has served me well enough up until now and 2) I didn't want to cough up the $145.  Maybe it's time to give it a whirl but it really would be great if there was a well supported Fusion 360 post processor.  Just say'n.
2 years 1 month ago #311089 by tommylight
@Sparkman61,
Please do not change the subject tittle when replying.
Thank you.
1 year 8 months ago - 1 year 8 months ago #321706 by Hakan
I have used the Fusion 360 QtPlasmaC postprocessor from here forum.linuxcnc.org/plasmac/38438-plasmac...ssors?start=0#162574 and overall it works good.
But for centerpunches (see the doc in the link) there is the error "M3 command before moves", which is that immediately before the M3 torch on line there are lines with only coordinates, they have to include also the G0 or G1 text. Fusion 360 normally takes them away as needed to save three bytes(?).
And the M3 command didn't switch on the torch but instead a marker device/laser cross.
Also a feed F99999 was commented out.
These are the changes needed from line 504 or so.
          var arcI = arcCenterX - circleData.center.x;           var arcJ = arcCenterY - circleData.center.y;           if (centerPunch) {             writeBlock(String("G0 "), xOutput.format(circleData.center.x), yOutput.format(circleData.center.y)); //move to start of entry arc - center of the hole           } else {             writeBlock(gMotionModal.format(0), xOutput.format(circleData.center.x), yOutput.format(circleData.center.y)); //move to start of entry arc - center of the hole           }           if (centerPunch) {             writeComment("CENTER PUNCH THE HOLE ONLY");             //writeBlock(feedOutput.format(99999));             writeBlock(mFormat.format(3), $Format.format(0), sFormat.format(1)); //start the torch             writeBlock(gFormat.format(91));             writeBlock(gFormat.format(1), xOutput.format(0.00001));             writeBlock(gFormat.format(90));
Last edit: 1 year 8 months ago by Hakan. Reason: why even try to use markups?
